Looking a 3100 topend...
Copper Head Gaskets?
Last edited by blownarrow; 06-04-2009, 03:37 PM.sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Tags: None
as far as i know, no company makes them. i'm sure a competent machine shop could make them fairly easily...
bumpLast edited by blownarrow; 06-04-2009, 03:37 PM.sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
who do you think has em now?...their for sale too..i dont need emOriginally posted by IsaacHayes View Posttejohnson had some made up once for his 3400.00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
