90 TGP Part Out!! Everythings gotta go!
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    For Sale : 90 TGP Part Out!! Everythings gotta go!
    just picked up this 90 TGP the engine locked up.. :icon_cry: The mains and crank bearings probably siezed due to gas in the oil.. So here she goes a complete part out.. Turbo has minimal shaft play feels really tight like it was recently rebuilt.. PM3 is good.. have 2 but one leaks.. Changed the backing plate to the rebuilt models that are steel rather than the leaky aluminum ones.. X-over has factory heat shield so thats self explanatory.. the turbo has a blanket on it maybe factory and it has heat shields the stainless ones.. Car came from utah so minimal rust but mainly rust free.. everything seems to be in good shape.. Someone local needs to grab the bumper... Im in south suburbs of CHICAGO which the town im in is BEECHER,IL Link.. http://maps.google.com/maps?sourceid...image&resnum=1
    I have another automatic that is rebuilt out of my 5 spd swapped TGP so thats up for sale.. anone thats local ill sell both together for a amazing deal..
    Edit: I have a Top Gun TG160 Chip
    And for that here are pics..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
  • dirtbean
    • Oct 2009
    • 7
    how much for the cpu, map sensor and those two top engine mounts compleate engine side brackets and all. i live in fl thanks
    • 94GPGTP
      95 Grand Prix GTP
      • Apr 2007
      • 593
      i have the ECM (cpu) and the engine bay harness.. would like to sell all together but i will seperate them..
      The engine mounts.. not sure what your talking about.. do you have a pic?
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        sounds like he's refering to the dogbones... or at least the dogone mounts/brackets.
        • dirtbean
          • Oct 2009
          • 7
          well what im trying to do is. i have a 95 acheva 3.1 ,automatic,egr pluged but still pluged in. and ive made a turbo kit for it 6psi put it on and i hooked a 8.1 fmu, 255lph fuel pump,but i tried to put check valves on the map sensor. and u can rev it up fine but as soon as u put into drive,and puttth as soon as u hit the gas pedal i mean the thing just cuts off then u let off the gas and it idles fine. it holds a steady 20 vacc and as soon as it goes up neer 5to0 it just cuts out bad un drivable. im thinking that i could put your cpu orpcm into my car your cpu is made for boost and the map .also
          can i put your whole harness back to the pcm ? it looks like your car has the 3.1 too
          if so how much do u want for theit all ?
          should i just get a chip ? and a bigger map sensor? i just did thid whole thing in effort to save gas but i hope i dint mess up my car
          any advice? or parts you might think i need ill take thanks for your help
          • dirtbean
            • Oct 2009
            • 7
            my cpu numb is 16196397 3 plug and it has a plate that i removed and their looks to be a chip but i dont know if its obd1,1.5,2 ?
            • dirtbean
              • Oct 2009
              • 7
              yes the engine stabilzers on the front,top of the motor they attach to the block and the metal support above the raditor and they look like dogbones
              • Monzsta
                • Jul 2007
                • 132
                How much for the manifolds, turbo, downpipe and plumbing?
                '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
                1/8 mile 9.72@75 mph, 2.0 60 foot
                • SofaKingWeToddDid
                  • Jul 2009
                  • 785
                  how much for the badges? (i like to collect these...)
                  • jmgtp
                    • 1219
                    If dirtbean doesn't take them I am interested in the dogbones, one of the dogbone radiator supports and the drivers side dogbone engine bracket:
                    1994 Corvette
                    LT1/ZF6
                    2006 Dodge Dakota 4x4
                    3.7/42RLE
                    • 94GPGTP
                      95 Grand Prix GTP
                      • Apr 2007
                      • 593
                      i might have them brackets somewhere..
                      Robert
                      New Rebuilt 3100
                      New Rebuilt 4T60-E
                      Exhaust
                      White
                      5 Speed Swapped
                      127,000
                      Spec Stage 3 Clutch
                      Emissions Deleted
                      • 94GPGTP
                        95 Grand Prix GTP
                        • Apr 2007
                        • 593
                        Sorry to burst everyones bubble.. Has anyone seen the orginal post date of this part out? this car was scrapped 9-10-09 looking like this
                        I dont want to scare anyone away but i do still have the parts to it.. Just give me a list of what you need and i may have it..
                        i know i have the engine bay harness and computer
                        no manifold turbo downpipe or plumbing..
                        Brackets maybe.. i have to check for the radiator support one but the other is on the engine still..
                        anything else LMK
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                        • SofaKingWeToddDid
                          • Jul 2009
                          • 785
                          tgp badges. how much?
                          • Monzsta
                            • Jul 2007
                            • 132
                            Crappazoids...
                            • SofaKingWeToddDid
                              • Jul 2009
                              • 785
                              wouldnt those engine brackets be the same as any old 3.1?
