Maybe F/S '92 PONTIAC Grand Prix SE 3.4TDC Manual
  • gpse3400
    • 1460
    Just throwing this out.
    Thinking of selling my '92 PONTIAC Grand Prix SE 2-Door. This is due to transaxle failure.
    199k Bright Red
    3.4 TDC and 5 Speed Standard Shift
    Leather Interior
    Pioneer Radio with 6 Pioneer speakers which includes 4x6 plates on the dash
    Gold Grand Prix Turbo Alcoa Wheels(not shown)
    '96 Front Brakes
    New intake gaskets
    Sealed oil pump drive
    New alternator
    Front brakes at 50% ceramic pads
    Rear brakes are new ceramic pads
    ABS
    COLD A/C
    Automatic day/night mirror
    New turn signal switch
    New turn signal relays
    New exterior lighting
    '97 Police Lumina Police car front springs
    new subframe bushings
    new front and rear stabilizer bushings/endlinks and rear stabilizer hangers(definately adds refinement)
    New wipers
    Cruise Control
    Polyurethane Shift bushings
    Rear Crossmember
    Power Windows, Mirrors, Locks, Trunk, and Antenna
    Keyless Entry
    Yellow Fog lights
    Trip Computer
    Full 2.5 inch exhaust with stainless tips, one Hooker Aero Chamber one Summit Turbo
    New Clutch
    New Clutch Hydraulics
    New tires 245 45 16 W Kelly EVO's
    STE truck lid Filler
    Rear plastic spring pads
    Stainless steel rear slider bushings for the rear brakes
    New parking brake cables
    Head-Up Display
    KYB Struts
    New engine mounts
    All sensors replaced
    All vacuum hoses replaced
    New AC Delco spark plugs and wires
    New radiator hoses, lower passenger side heater line repaired.
    High Flow Catalyst
    New fuel pump
    Timing belt system and serpentine belt with tensioner and pulley has 27 K on it.
    Issues
    power door lock motors are weak when cold out
    power antenna doesn't extend fully all the time
    Its a little wet between the rear cam carrier and the rear head (not the oil pump drive, that is sealed up good) otherwise the car and engine is dry
    Drivers side window switch sticks in auto down and will trip the breaker if not manually released
    Brake booster has a very minor leak. The pedal will get hard to push after the engine is shut down for a while
    And the big one, the Transaxle locked. Needs to be replaced.
    Overview
    Is a good car and everything essentially works. It tracks straight, stops, accelerates, and steers very well, an excellent comfortable cruiser and handler. Engine makes excellent oil pressure, runs smooth and alternator output is nominal. It isnt perfect at 199K but it is really nice clean, and civilized car. I am curious as to what I could get for it. I do love the car but the transaxle issue has put me to the limit and I really do not need the car. Bottom line all it needs to be driven is a gear box. PM me with interested offers please. This car needs to be moving not parked.
    Lorenzo
  • SofaKingWeToddDid
    • Jul 2009
    • 785
    dont forget about the calculator built in to the steering wheel! its one of those graphing ones we had to use in highschool! those arent cheap
    • gpse3400
      • 1460
      Yes sir it has that too! Thanks for remindinding me! Acutually the steering wheel controls do not work with the new radio but I have the aftermarket PAC controller which I never bothered to hook up as the remote control works just fine....I got a lot of spare parts to let it go with as well.
      Lorenzo
