Lots of 3.4 DOHC Parts Mostly 1996/97
  • jmgtp
    • 1219
    For Sale : Lots of 3.4 DOHC Parts Mostly 1996/97
    Hello All,
    Here are some 3.4 DOHC (LQ1) parts for sale. Most are 96/97 but evertthing is labeled. I have clean feedback on the board and 100% on eBay (seller jmgtp). I prefer paypal.
    Thanks,
    John
    Pics for all items will be in the following post.
    If interested PM or post with your zip and I will get shipping quotes.
    96-97 3.4 DOHC Top End Set
    Includes: Upper Intake Manifold/Plenum, Throttle arm w/brake booster adapter, lower intake manifold, thermostat housing, fuel rail with FPR. Does not include throttlebody.
    $90 + shipping
    96/97 3.4 DOHC Upper Intake Manifold/Plenum
    $25 + shipping
    96/97 3.4 DOHC Throttle Arm (connects TB to Plenum)
    $15 + shipping
    96/97 3.4 DOHC Fuel Rail
    does not include regulator
    $10 + shipping
    96/97 3.4 DOHC Thermostat Housing w/ bleeder
    $5 + shipping
    96/97 EGR Valve
    I've never used it so I couldn't say if it works or not.
    $5 + shipping
    96/97 3.4 DOHC Plenum Gasket
    $5 + shipping
    1991 3.4 DOHC Cam Gears, Lock Rings, Bolts
    Good shape.
    $10 + shipping
    1991 3.4 DOHC Oil Valley Gasket
    $3 + shipping
    1991 3.4 DOHC Lower Intake w/thermostat housing
    the runners have been sanded fairly smooth. Enough to get rid of the rough cast finish.
    $15 + shipping
    NON 3.4 DOHC STUFF:
    LS1 Throttlebody 75mm, Includes TPS and IAC
    SOLD
    3.1 MPFI Throttlebody
    needs new gasket for lower section and possible the securing bolts. If I can find the bolts I will include them.
    $5 + shipping
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
  • jmgtp
    • 1219
    Be sure to see the descriptions in the above post as there may be additional info.
    $90 + shipping
    sorry I didn't take a pic, it is pretty much identical to the one pictured above - just included the upper intake/plenum only. If you need a pic let me know I'll take one.
    $25 + shipping
    $15 + shipping
    $10 + shipping
    $5 + shipping
    96/97 EGR Valve
    $5 + shipping
    96/97 3.4 DOHC Plenum Gasket (New In Box) sorry the flash kinda washed it out. It is NIB Felpro
    $5 + shipping
    $10 + shipping
    1991 3.4 DOHC Oil Valley Gasket - never used, new
    $3 + shipping
    $15 + shipping
    NON 3.4 DOHC STUFF:
    SOLD
    $5 + shipping
    1994 Corvette
    LT1/ZF6
    3.7/42RLE
    • 94GPGTP
      95 Grand Prix GTP
      • Apr 2007
      • 593
      is there some sort of clip that hold the fuel lines to the fuel rail? These are some nice parts BTW..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      Drilled/Slotted Rotors
      White
      3" Magnaflow Catback
      90 Pontiac Turbo Grand Prix
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      230,000 mile Getrag 282
      Emissions Deleted
      Brand new Engine 1,000 Miles
      Fully Custom Built car
      • CNCguy
        Bisong eater :P
        • 1017
        How much to ship the LS1 TB to 45449?
        MinusOne - 3100 - 4T60E
        '79 MGB - LZ9 - T5
        http://www.tcemotorsports.com
        • jmgtp
          • 1219
          94GPGTP... yes there is a clip that attaches the lines to the rail. I can sell you the whole rail.
          CNCguy - I can check on a shipping quote tomorrow for the TB.
          1994 Corvette
          LT1/ZF6
          3.7/42RLE
          • jmgtp
            • 1219
            CNCGuy... sorry for the delay. Shipping is $7 for a total of $32.
            I want to be as honest as possible about the TB so I took some better pics. I realized there is something major that I did to it that I didn't realize at the time of original posting. That is I ground away the area beneath the IAC passage. The reason i did this is because I was mounting the TB to a flat plate that had only a 3" bore with no accommodations for an IAC passage above the throttle bore. By grinding away the area between the throttle bore and IAC this allowed the metered IAC air to pass into the bore area behind the TB plate. The below pics demonstrate the changes I made for the IAC passage. I ran it like this on my 3.4 for a few years before swapping a Northstar TB in.
            If this is a problem for you I understand - I can knock $5 off the top if it is and you are still interested.
            Thanks,
            John
            1994 Corvette
            LT1/ZF6
            3.7/42RLE
            • 94GPGTP
              95 Grand Prix GTP
              • Apr 2007
              • 593
              I really don't need the whole rail. I just picked up a parts car and it has AIR. Do you have non AIR exhaust manifolds. Of course 96/96..
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
              • CNCguy
                Bisong eater :P
                • 1017
                What's email for paypal? I saw the slot and it's fine for me as I do the same thing to them. Saves me a little work.
                '79 MGB - LZ9 - T5
                • jmgtp
                  • 1219
                  Sorry I can't split the fuel line clip from the rail since that makes the rail useless. I don't have the exhaust manifolds.
                  1994 Corvette
                  LT1/ZF6
                  3.7/42RLE
                  • jmgtp
                    • 1219
                    Please send to johnmontauti@yahoo.com - I should be able to ship within a day or two of payment.
                    Thanks,
                    John
                    1994 Corvette
                    LT1/ZF6
                    3.7/42RLE
                      I don't believe any of the 96/97 cars came without AIR injection. I took the set I got on a set of heads and cut the injection tube 1/2 inch above the flare nut, pinched them some and welded them shut.
                      John, is the LS1 TB a direct bolt on to the 96/97 style intake?
                      • jmgtp
                        • 1219
                        Jon, no it is not a direct bolt on (it is also sold - I will update the posting).
                        THe 96/97 intake has a ~2.5" mount I believe at the throttle arm TB end. The LS1 TB is ~3". I had a custom built throttle arm that allowed for the LS1 TB... it'll be up for sale down the road when the LQ1 comes out.
                        1994 Corvette
                        LT1/ZF6
                        3.7/42RLE
                          I was asking more for clarification on my part if it was a bolt on item, I knew Marc already had dibs Thanks for the explanation
                          • CNCguy
                            Bisong eater :P
                            • 1017
                            Bump for John for being a good seller and a nice guy.
                            '79 MGB - LZ9 - T5
