FEELER: Reground 3400 cam for 6500+ RPM
  • discostu
    • Jul 2005
    • 105
    I'm looking at selling a 3400 cam I had reground and never used.
    The specs on it are as follows:
    216/220 rated duration, 276/280 adv duration
    .472"/.498" lift with 1.6 rockers. Stock ICL and LCA, single tooth cam sensor.
    This cam is perfect for use with the LS6 yellow springs which support about .510" lift.
    It will make peak power at 6500rpm when combined with ported heads, intake and exhaust.
    Desktop Dyno reports +9 hp and very little loss in torque (0-2 ft-lbs depending on the mods you have) when using this cam vs the stock cam in a modded engine.
    Even on a bone stock engine you should pick up about +6 hp with this cam, and be able to rev 500 rpm higher.
    Looking to get $200 CDN + shipping.
