Assorted S10 2.8 & Camaro 3.4 items
  • paxter
    • Oct 2009
    • 6
    Going through my shop today and have some items to sale.
    1. I have a 3.4 block (94 camaro) that has been bored .040 over. The final bore has not been done, but it is up to needing the pistons to do the final bore/hone. $150
    2. 3.4 pistons/rings (.020 over) used, but with less than 2k miles on them probably 1K, with rods that have been reconditioned. I planned to re-use them in this block, but I had to go .040 over to clean up the block I bought. $200.
    3. I have 2 complete camaro intakes and one has a harness and ecm. I believe 2 of the connectors have been dyked (not by me), but in otherwise good condition. Make reasonable offer
    4. 84 2.8 engine complete minus carb., rod bearing started to knock and was immediately shut down. I would consider it to be a good rebuildable core. Not sure if I have valve covers, but oil pan is there also. $200. I think this would have to be a local pickup (Gulf coast of Alabama).
    I have some other assorted BS out there and I'll post it here as I go through it.
    I'll consider any reasonable offers on all items.
  • 2.8/3400 1985 Camaro
    • Nov 2009
    • 192
    Engine harness or just injector harness I am looking for a 94 auto ECM for 3.4, or 93-95 manual ECM with harness.
    http://www.cardomain.com/ride/390342...evrolet-camaro
    • paxter
      • Oct 2009
      • 6
      Its the entire harness, but like I said I believe 1 or 2 of the connectors were cut. I'll look at it tomorrow and take a picture. I think I have the ecm too.
        • Nov 2009
        • 192
        What is the harness out of specifically, cause I very specifically need it to be a 93 if its from an auto(said wrong year in first post), or from a manual, for a 3.4 fbody.
        • paxter
          • Oct 2009
          • 6
          Its out of a 3.4 auto F-body 93-95. I do not know what year it specifically came out of.
            • Nov 2009
            • 192
            Do you have the car it came out of? Because I'm afraid I can't pull a trigger without being absolutely certain that its from a 93, any later and it will have a transmission controller built into it for an electronically controlled transmission, which would be incompatible with my application.
