Misc parts left over from my 92 Z24
  • danbettis
    • 66
    For Sale : Misc parts left over from my 92 Z24
    Still have some things left. All are from my 92 Z24. Most are listed here also http://www.zrracing.com/forsale.htm
    Chip (with ECM), no top speed governor. 92 Z24 manual. No top speed governor and more power to boot. This is out of my 92 Z24 with a manual trans. Chip is aggressive, requires 91 or better octane fuel. Increased fuel millage while cruising 3-4 mpg. $100
    Rear springs custom made, about 1" 1-1/2" lowering 800lb spring rate, 550lb wheel rate, these are very stiff you will want coil overs for the front with these. $100
    Rear sway bar, 26mm. $100
    Rear sway bar and springs $175. These to get will make your car turn much better than any after market stuff.
    3.1L ported heads, upper and lower intake, and 56mm throttle body - $300
    W-41 Transaxle with V6 bell housing - 3.94 final drive, 3.50 first, 2.05 second, 1.38, third, 1.03 forth, and .81 fifth gear - $300
    Workshop manual 1992 Cavalier/Z24 on CD. Is AllDATA, like AutoZone sells but on CD and no expiration date. - $20
    Four stock Z24 wheels, 15 x 6 - $150
    Four American Racing AR-55 15 x 7 wheels. These need some serious cleaning, but still great for autox or track days. Could be painted - $150
    Stock Z24 strut tower brace. - $25
    Also have a bunch of 3100 and 3400 parts. 2000 to 2002ish. Castings, sensors, EGRs, pulleys, and so on. Some are listed on my web page.
    Front covers with water pump 3100-3400. NEW - Front cover with water pump and crank sensor, 1 available - $50. USED - Front cover with water pump, 1 available - $30
    Dan
    [/url]http://www.youtube.com/user/zrracing4
  • Rootie524
    • Feb 2010
    • 543
    pic of heads?
    • danbettis
      • 66
      Old and recent pics are located here. Parts need cleaning. http://www.zrracing.com/z24-engine_2010.htm
      Dan
      • danbettis
        • 66
        bump
        Dan
