94 Olds Cutlass Convtible w/3.4L DOHC 86k mi
  • Scott205
    • Jun 2005
    • 265
    For Sale : 94 Olds Cutlass Convtible w/3.4L DOHC 86k mi
ID:	379607Click image for larger version
ID:	379604Click image for larger version
ID:	379608Click image for larger version
ID:	379605Click image for larger version
ID:	379606Click image for larger version
ID:	379592Click image for larger version
ID:	379593Click image for larger version
ID:	379594Click image for larger version
ID:	379595I am selling my 94 triple black convertible. It has 86k miles, most everything is original. Cold a/c, current inspection (emission here in texas are the same as cali), current license sticker. Top works great, runs like the wind, very reliable.
    I am asking $2750 or OBO!
    Runs great, has small oil leak on front head, 1st owner did a timing belt shortly before he sold it and it has leaked since. It loses less than 1/3 qt over a 5,000 mi (mobil1 syn) oil change and that is usually when it has set and had very few miles. I bought it with about 82k miles in 2005, so I have put very few miles on it.
    I have recently replaced the front brakes and changed the brake fluid (vaccummed not chemical), and also the A/c Compressor. I have replaced the HUD switch, turn signal switch, ash tray (previous owner had a bunch of electronics installed), and a bunch of other things. I immediately started using Mobil 1 syn oil and changed the trans fluid and filter. I have also changed the Coolant last month and the power steering fluid.
    The flaws: It has small oil leak on front head (1st owner did a timing belt shortly before he sold it and it has leaked since especially when sitting for long periods of time). It loses less than 1/3 qt over a 5,000 mi (mobil1 syn) oil change and that is usually when it has set and had very few miles. Typical door dings and swirl marks of a 16yo car, top looks very old (it is the original) and has faded a bit, the rear curtain is sealed only on the sides in the rear, it lets a bit of water to leak into the rear vinyl that protects the top when down. The 1st owner also had cut a hole into the trunk to pass a magnetic antenna for cbs and fm radio. It has the marks where the antenna was and the hole was plugged and painted. There are also a few small holes in the top of the dash where the 1st owner had a monitor for gps. The drivers side door master lock/window switch doesn't sit squarely into the door, but works well. The rr quarter window doesn't work. The trunk had a bunch of water leak into it from the hole and that screwed up the jack (I will give you my jack from my 90 lumina).
    2014 Chevy Cruise LT
    2000 Kawasaki ZX-6R Ninja Motorcycle
  • Scott205
    • Jun 2005
    • 265
    Oh, it passsed Texas state inspection (we are emissions, same as California in the 5 counties around houston) back in 6/10 and has a current license plate sticker from 5/10.
    • Scott205
      • Jun 2005
      • 265
      New pics are up, have to take one of the underside, never did that before.
