massive part out
  • Rootie524
    • Feb 2010
    • 543
    massive part out
    well my 3100 malibu is toast. timing chain damper split in half, got stuck in the chain..halted the motor..crankshaft keyway snapped so the crank kept spinning but the cam didn't and it sent a valve through my piston. literally.
    so it's time to part out. probably just going to drop a 3500 in it and call it a day.
    up for sale performance wise:
    comp 26986 valve springs - $90
    comp cams custom ground cam - $200
    --intake lift .487 exhaust lift .502
    custom length pushrods - $90
    tuned PCM w/ ignition timing advance, raised shift points/pressures, limiters removed, etc..pm for more details. - $150
    brand new never used eibach lowering springs - $210
    brand new never used pacesetter header kit - $320
    other stock things:
    56mm throttle body - $20
    UIM - $20
    LIM - $25
    oil pan - $20
    brand new timing set (the older/thicker style) - $25
    timing chain cover - $20
    alternator - $70
    starter - $50
    (3) coil packs - $10 each
    ignition control module - $40
    4t40e transmission w/ 112k on it (pick up) - $150
    lifters w/ TCE lifter springs installed! - $70
    stock fuel pressure regulator - $15
    fuel rail w/ stock injectors - $45
    exhaust manifolds - $25
    let me know if there is something you need and ill see if i have it. obviously the block, heads, valves, crank, and all those things are shot. the pushrods did not bend though! they just sacrificed the rocker arms.
    ALL PRICES ARE OBO AND DOES NOT INCLUDE SHIPPING.
  • mickaz
    • Aug 2004
    • 350
    everything you got listed for performance can be kept and installed into a 3500...just swap out the stuff you will be ahead in a powerful build.
    Mike 60degree addict.
    • Azrael
      Accelerating uphill in OD
      • Apr 2005
      • 763
      Wouldn't the TCE lifter springs work in a 3500 as well?
      1995 Grand Am SE
      • mra32
        91 Lumina LHO
        • Jul 2006
        • 6
        Not sure if the injectors will fit my 91 LHO lumina, but interested. Where in PA are you?
        Mike A.
        COP SEATS
        COP BRAKES
        COP HEADLIGHTS aus deuchland
        COP SHOCKS
        COP SUNGLASSES
        what do you say? is it the new elfmobile?
        • Rootie524
          • Feb 2010
          • 543
          near allentown.
          • eeltam
            • Oct 2010
            • 11
            I wil take the uim and lim if they are still available.
            • 92cavquest
              • Feb 2008
              • 150
              Any idea how that cam would be in a 3500?
              • Rootie524
                • Feb 2010
                • 543
                UIM is sold. still have the LIM.
                and the cam would be the same way it is in my 3100. its pretty lopey. and a custom torque converter is highly recommended because i was already rocking back and forth at stop lights. i kinda liked it tho haha
