Getrag 284 Setup
  • 1LoudCutty
    Yeah, it's slow. For now.
    • Feb 2008
    • 23
    For Sale : Getrag 284 Setup
    Alright, lets try this thread again without a bunch of debate on what trans I actually have. Ill start off, I know it's a 284 just like I previously posted for sale. It says 284 right on the trans tag and I pulled it myself from a 92 GTP.
    IIRC mileage on trans is 127K. Engine in car was junk. Trans shifts easily through all the gears.
    What's included?
    -Trans (127K IIRC)
    -Tail shaft to engine block bracket. Slightly cracked, easily repaired. I haven't seen many uncracked.
    -Repaired/modded trans mount. Poly filled. Looks nice
    -Shift cables, has grommets in place. Move freely, comes with new "Nunzi Mod" bushings, washers, clips
    -Shifter and mount clips, round style GP. No shift knob
    -Firewall plate, modded auto unit. clutch MC fits nicely and securely
    -Column/Pedal bracket assembly. Proper 5-speed unit
    -Master Cylinder
    -Slave Cylinder
    -Stock line, but comes with Pinlock to -3AN fittings so you can use a prefabbed braided stainless hose instead of the stock line and crappy accumulator setup. Summit sells the prefabbed hoses for aboot $20. Not sure of length needed
    -NEW (Not Reman) flywheel. Has been bolted to my LX9
    -NEW (Not Reman) Axles, both sides with stub shaft
    -Trans to block bolts
    -VSS and reverse switches in trans with pigtails.
    -Has a dipstick (thanks Nunzi!)
    You will need a clutch set and flywheel bolts. Nunzi says Auto bolts wont work as they are a bit too short. I bolted the flywheel to my LX9 with the stock LX9 bolts and they seem to engage plenty of threads. AFAIK, LX9 bolts are not the same as LQ1/3x00 thread pitch anyway so I won't be including mine.
    Will need the trans fluid, and I recommend new axle output shaft seals. They are less than $20 for both.
    And that's aboot all. Add clutch, flywheel bolts, 2 seals, fluid, and enjoy shifting. I'm looking to get rid of it cause well, it's just not gonna fit what I really want. Time to realize a 284 isn't realistic for my goals.
    Asking $900 OBO or TRADE
    Got a decent running not rotted out spare W-body or other car? I'll trade straight up for this setup. I'm also willing to trade for other stuff, just ask!!
    Any questions, lemme know. I can get pics up upon request. Nothing special, tis gonna look exactly as I described
    -Bob
    92 Cutlass Supreme Convertible DD, rolling on 19's
    90 TGP LX9T/4T60e Project, rolling on jackstands
    08 Kia Specta SX Family Hauler
    -Bob
    IIRC if you used a 90 degree fitting on the trans end, you would need around a 18-20" line.
    Whoever buys this for sure would want to get manual flywheel and not auto flexplate bolts, like mentioned above. The flexplate for an auto is very thin compared to a flywheel.
    • Dave96z34
      • Apr 2005
      • 624
      No shift knob?
      • jmgtp
        • 1219
        Thread pitch has to be the same. Otherwise the flywheel bolts that came out of my LQ1 crank would not have threaded into my LX9 crank.
        1994 Corvette
        LT1/ZF6
        2006 Dodge Dakota 4x4
        3.7/42RLE
        • Dave96z34
          • Apr 2005
          • 624
          • 1LoudCutty
            • Feb 2008
            • 23
            Ok, I wasn't sure on the pitch. I had a bunch of 3x00 flexplate bolts so I thought, but they turned out to be L67 ones.
            IIRC The bolt needed is a M10x1.0 and aboot 20-22mm long.
            No shift knob, the one that was on it looked like a wolf chewed it up.
            • 1LoudCutty
              • Feb 2008
              • 23
              Willing to take $750 for everything,
              I can store for around 6 months until it can be picked up. Would save alot on shipping obviously,
              Located in Lorain, Ohio 44055
              • gtptuner
                • Apr 2010
                • 48
                I would be willing to buy some of your parts
                - trans mount with pollys
                -Shift cables,
                -Master Cylinder
                -Slave Cylinder
                - Axles, both sides
