3500 UIM/65mm tb, powdercoated pulley set
  • MidnightriderZ24
    • Jan 2005
    • 699
    i got a few parts that are collecting dust ready to go. powdercoated pulley set, bright silver. comes with polished w/p pulley,alternator pulley and fan, belt tensioner, idler pulley and bolt, p/s pulley and a new 3500 balancer and newer dayco belt to fit. $130 shipped.
    I also have a ported 3500 upper powder coated in the same bright silver, cut off and welded egr/evap ports. the intake comes with a ported/polished lx5 65mm throttle body and wot-tech adapter and throttle cable bracket. This also comes with polished 3/8'' spacers with 4 good 3500 gaskets and required hardware. $150 shipped
    *needs 2 throttle body bolts, wot-tech bolts were too short with the throttle cable bracket, no iac valve, tps, or an fittings*
    Mind you these have been scratched from being moved from shop to shop, but theyre still good looking parts.
    [SIGPIC]
    12.268@117... 11's to come!
  • beastberetta
    • Mar 2010
    • 87
    pm sent.
    [COLOR="red"]1996 beretta z26, 3500 v6 currently awaiting my holset hx35 COLOR]
    • eckoxl
      • Jul 2009
      • 230
      Ill take the 3500 UIM and stuffs
      1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
      • MidnightriderZ24
        • Jan 2005
        • 699
        sorry intake and parts are sold. pulley set still available
        [SIGPIC]
