MPFI system
  • mingo
    • Nov 2010
    • 15
    For Sale : MPFI system
    SOLD!!!!!!!Complete MPFI from an 86 Camaro. Includes upper plenum w/throttle body, middle and lower manifolds. Fuel rail assembly w/injectors and pressure regulator. Cold start injector, Distributor with plug wires, and complete wiring harness with ECM 1227302. Also included is the air intake with the MAF and air temp sender. Should be everything needed to install a EFI system. Will fit 2.8L,3.1L, and I think the 3.4L RWD iron heads engines. Wiring harness has most of the connectors labeled, but not all.
    Was going to install this on my 3.1L in a MGB. But decided on going the carb route. $150.00
    Buyer pays shipping. Thanks
