Idler pullies...
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    Idler pullies...
    I need a 3500 idler that goes where the powersteering pump went on earlier cars, also, can anyone confirm that a 3400 timing cover is the same as a 3500 in that area? mainly, can you bolt the 3500 idler to a 3400 cover?
    Live life 3.7mi at a time
    • 4555
    I have a box of them. Are you talking about the one at the bottom right hand side when looking at the timing cover? It's just a standard smooth idler pulley. I have a pile of the ribbed pulleys as well.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      nah, I'm talking about the one that goes on the top right of the timing cover, so the water pump spins on a motor that doesn't have a power steering pump.
        • 4555
        Which one? The P/S pump is in the same position on the 3500 as earlier motors...
        http://60degreev6.com/forum/showthread.php/41003
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          The pulley that goes here!
          I assume that pulley stand-off like seen in the center except it bolts on. am I correct in thinking that?
            • 4555
            Do you have a pic of all the pulleys you are trying to use? I looked at your thread and it's hard to tell your planned routing via pics.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              you can see the routing in that pic best, left of the alt. down to the bottom of the crank, to the left of the ps, to the bottom of the a/c, to the wp, over the idler, under the tensioner, and back to the alternator.
                • 4555
                The 3500 tensioner hit the P/S? Almost looks like it's going to work in the pic if your belt was longer. You also have the spot inline from the crank to W/P that can hold an idler pulley, and either ribbed or smooth.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  it's not the tensioner that's the problem, (well, my new one is, but that's another thread...) it's the ps mount, the belt would touch it and get destroyed in a matter of seconds...
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    and this thread can be closed, I'm gonna have to go to the jy for a couple of other parts anyways, so I'll just pull them while I'm there.
