1985 Camaro with 3.4l v6 (Pittsburgh, PA)
  • 2.8/3400 1985 Camaro
    • Nov 2009
    • 192
    For Sale : 1985 Camaro with 3.4l v6 (Pittsburgh, PA)
    It is a project or parts car(whole car, I do not have time or energy to part it out), I would like to get $700, but will take the best offer, I have a lot of good parts on the car, and don't want to sell it to a junkyard for $200, so they can crush $1k worth of pretty much new parts.
    It has t-tops, 700r4 transmission(has an issue upshifting to 2nd, but is fine while in 2nd, and downshifting into 2nd), needs driver side floorpan, interior is gutted(I still have it, except carpet/foam, and dashpad, no hvac. I have no longer have the time or interest to work on it, I have a 3.4l iron head motor from a 94 camaro in it, with 160k on the bottom end, the heads have new stem seals. It currently does not run because I started messing with the engine management and screwed things up(or the ecm I got was bad), I was in the process of wiring up a harness from a 4th gen car, and was going to run a 730 ecm(alternatively it could be converted to carb, otherwise a complete donor engine harness+relays+dash harness,(and possibly distributor and plenum(I cannot remember if I have them still)),I just don't have the time or patience anymore, and am moving soon so need it gone.
    As for parts replaced/mods:
    -new rear shocks(monroe)
    -new rear springs(moog)
    -new front end links
    -new front rotors and pads(rotors need cut from sitting so long)
    -IROC-z rims(tires are no good, but I have a set I could put with the car, 7/32 on one pair, and 11/32 but cupping on the other)
    -fiberglass pin on hood
    -255 lph fuel pump
    -B&M ratchet shifter
    -3.4l v6, with 260 delta cam+new lifters, new stem seals on heads
    -Pacesetter headers
    -magnaflow cat
    -dynomax catback
    -Moroso switch panel(6 rockers+5 20 amp breakers) if someone wants to continue on where I left off, otherwise I will keep it.
    -left? rear brake line
    -gutted factory cold air dual snorkel intake box with K&Ns
    -new windshield and rearview mirror installed by safelite
    Probably more parts/mods that I cannot remember.
    Call/text: 412-969-0226, or email: jd_goetz@yahoo.com
    http://www.cardomain.com/ride/390342...evrolet-camaro
