1990 3.1L MPFI injectors
    Wanted 1990 3.1L MPFI injectors
    Need a set of known GOOD 3.1L injectors unless people know the 90 MPFI 3.1's can be replaced by the SFI 94-96 3.1L injectors without any issues.
    I know the SFI 94-99 3.1's were 17lb but I don't know what the MPFI injectors are.
    Scratch the swapping in.. They are 15lb/hr injectors... and the SFI 3100 ones are 17lb/hr
    I could swap it if I could flash the ECU or just deal with the slight correction... it would probably work fine for what I need it to do.
    actually, 3.1MPFI(aluminum head at least) are 16.7, the 93-99 3100 injectors are ~17.4.
    at least, that is what i have found documentation on from various sources.
      Since no one has these I guess I'll just use a set of 3100 SFI injectors and hope for the best and adjust the ECU later when I get some OBDI tools.
