Anyone Looking For a Turbo Kit?
  • 85maro
    • Sep 2006
    • 140
    I have a ton of unused tubing, a T3 and some silicone connectors my better half says needs to go, if anyone is interested I can weld up a turbo kit. It will have a similar fwd manifold to what fasteddi on thirdgen.com used that put him in the 12's. I can supply injectors and other odds & ends as well. Price will be around $3-400 depending on what you want. Basically the exhaust up to the turbo will be finished and you route it where you want after that.
  • 85maro
    • Sep 2006
    • 140
    Still out there if anyone's interested.
    • coolraptor
      • Dec 2013
      • 7
      Could/would you be able to make a set of manifolds/headers for a t3/t4 hybrid turbo on a 2000 Impala with the 3.4? Like the whole hotside basically?
      2000 Chevy Impala, 3500 top Swapped, Overkill Tune, 42lb Injectors, EGR Delete, LS Lifter Springs Mod, TB coolant Bypass, 'warm air intake', 4t65HD Trans Conversion w/ shiftkit, - KYB GR2 Struts, LS1 Fbody brakes, GM Rear STB w/ Done Rome Brackets, Resonator delete & 2.5inch exhaust.
      1995 Chevy Camaro Z28 - 383ci LT1 pt76, 6speed, drag car.
      • 85maro
        • Sep 2006
        • 140
        I don't have access to an impala so I can't sorry.
        • coolraptor
          • Dec 2013
          • 7
          No problem! Thanks!
          • hookdonspeed
            • Jun 2007
            • 322
            where are you located? im looking for a turbo setup for my 3500 fiero
            • caffeine
              • Jan 2012
              • 1489
              From what I've seen isn't the easiest Fiero turbo setup just a stock crossover style exhaust (like Uplanders) with a turbo flange welded/adapted on the end?
              '86 Fiero, 3500, 4-speed
              • hookdonspeed
                • Jun 2007
                • 322
                if you wana loose the trunk yes, but i also have a 4speed in my 3500 and you cant use the stock 3400 style crossovers, hits the shift linkage, i may goto a 5speed, but either way, i currently have 2 "front" 3500 manifolds.
                • project 92z
                  • Feb 2011
                  • 143
                  I might be interested. I have a 92 3.4 DOHC motor. Could you do anything for that? I might even be able to find a front exhaust manifold or whatever else you might need. Would love that extra lil bit of power
                  • 85maro
                    • Sep 2006
                    • 140
                    I sold off the rest of my tubing awhile ago actually.
                    • project 92z
                      • Feb 2011
                      • 143
                      Really sorry to hear that. But if you come across more or areever interested in doing a mock up bolt on, keep me in mind.
