WOT-Tech Grind #1280 N/A Performance Cam
  • onefastV6
    • Sep 2005
    • 880
    For Sale : WOT-Tech Grind #1280 N/A Performance Cam
    WOT-Tech Camshaft Grind #1280 N/A Performance Camshaft with proper length pushrods: $250.00 + Shipping
    This was WOT-Tech's old stage 3 performance cam, which was ground on a solid core camshaft. It is in excellent condition and only has about 45 mins of run time as the engine developed rod knock shortly after the car was driven.
    Specs: .323/.337" lobe lift, 212/220 degrees duration @ .050". Factory 1.6:1 roller rocker arms will give a gross valve lift of .517/.539".
    For those interested in a sound clip, you can check this thread http://60degreev6.com/forum/showthre...l=1#post466172 as mfuller is running also running a #1280 grind cam.
    2000 Grand Am GT
    2011 Chevy Impala
  • NateD4
    • Mar 2011
    • 576
    Can you post a picture?
    • onefastV6
      • Sep 2005
      • 880
      Pics added
      2000 Grand Am GT
      2011 Chevy Impala
