New set of 12 LS-6 beehive valve springs.
  • trotterlg
    • Feb 2011
    • 326
    New never installed set of 12 factory LS-6 valve springs. A nice easy spring upgrade for the 3100 3400 etc and some others. Here is a link to some info: http://members.shaw.ca/howto/vortec/vspring.htm these springs meaured as follows:
    Bottom ID .850
    top ID .640
    Bottom OD 1.280
    Top OD 1.070
    Free height 2.110
    Measured coil bind is 1.210
    Seat pressure at 1.8 install is 90 Pounds
    Open pressure at 1.28 is 259 pounds
    Good for .520 lift or a little more if installed at 1.8. Install shorter for more seat pressure and less lift.
    Nice upgrade for the 3100 series, installed with stock retainer and new valves and never ground seats will give you an install height of 1.7 inches. Grind the valves and seats and you will be close to the 1.8 number.
    These are the new production Blue LS-6 springs, the old ones were Yellow.
    Full set for $30.00 I pay the shipping to you. I have 3 sets avaliable. Larry Trotter
  • rayruner
    • Apr 2010
    • 40
    I have a 98 2.2 s-10, do you know if your springs will work on that 2.2 motor, they are new, never used is that correct. thanks
    • rayruner
      • Apr 2010
      • 40
      Also do you have a part #
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        You have the seats for these springs?
        • tubov6cav
          • Mar 2014
          • 63
          do you have anymore sets of these?
          • trotterlg
            • Feb 2011
            • 326
            Sorry, I only have 4 springs left now. Larry
