FS: OEM connecting rods w/ ARP bolts
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    For sale is a set of 6 OEM forged steel connecting rods for the 3400 V6. They have been fitted with ARP rod bolts and nuts, but the rods will need to be sized before use.
    Asking for $50US plus shipping.
    Thanks for looking.
    Sent from my iPad using Tapatalk
    Matt
  • Bridgetown
    • Jan 2008
    • 174
    Can elaborate on this a bit?
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      In a nut shell, the clamping force of the ARP hardware is different than stock, so you want to have the sizing checked and machined if necessary to make sure the bearings have the proper clearance when you put everything together.
      The installation of new bolts can cause the parting line between the cap and the rod to shift ever so slightly, and this misalignment can create a tight spot between the rod bearing and the crankshaft journal, which will scrape away some of the lubricating film of oil and foster a hot spot.
      Some rods will exhibit more shift than others, so it's a good idea to have any rods sized when you change bolts.
      Matt
      • tubov6cav
        • Mar 2014
        • 63
        still have these?
        • mfuller
          Mr. Common Sense
          • Nov 2003
          • 374
          I'm sorry; these have been sold.
          Sent from my iPhone using Tapatalk
          Matt
