WTB: 3.1L Gen-I Pistons
  • Canyonero
    Plays with Volvos now.
    • Sep 2006
    • 1112
    I have a 2.8L block that I'd like to stroke to 3.1L, I already have the crankshaft. Anyone have some 3.1L iron-head pistons they'd like to get rid of? This block doesn't have a crank sensor so I can't build a Gen-III hybrid out of it. Trying to make use of the parts I have on-hand.
    Thanks
  • DefEddie
    • Aug 2009
    • 194
    Do you mean 3.1 gen2 pistons? The only difference between 2.8/3.1 is the stroke of crank,pretty sure you can reuse the 2.8 pistons/rods unless you're using the genIII heads.
    The genIII pistons are different as well as CC in heads,so there is some hokey pokey between them if you are using the newer genIII heads pretty sure for compression.
    • Canyonero
      • Sep 2006
      • 1112
      Either the pistons or the rods are different, maybe both. Otherwise the piston would overrun the cylinder and contact the head. I'm just trying to build an ordinary Gen-I engine.
        rods between 2.8 and 3.1 are the same IIRC.
        pin height being different between 2.8 and 3.1 would make sense.
        • Canyonero
          • Sep 2006
          • 1112
          I think a set of pistons is $120 or so, maybe I should just get them new.
          Sent from my XT1058 using Tapatalk
          • Canyonero
            • Sep 2006
            • 1112
            I think these are the right ones.
            Get fast, Free Standard Shipping on orders over Summit Racing Equipment from $109 -- no shipping, handling, or rural fees! Exclusions apply.
              those certainly seem to be 3.1 gen1 applications.
              • DefEddie
                • Aug 2009
                • 194
                K,was wondering cause i've prob got 3100 and 2.8 and 3.4 pistons but only gen2 pistons i had were the tgp pistons.
                Always love learning,problem is while some is coming in I think some is going out
