3.4L Powered Isuzu Trooper
  • Canyonero
    Plays with Volvos now.
    • Sep 2006
    • 1112
    Anyone want to buy my modified Trooper for hella cheap? $3000 It's just time for me to move on. I've owned the truck since 2002. Basically replaced it with my P38 Range Rover two years ago.
    The big thing is the engine, has a 3.4L running on MPFI with a GM 1227727 ECU, runs ok but should be fine-tuned. Swapping injectors back to stock size might bring the tune closer, I put in 24# injectors, stock is 17#. I did modify the tune to account for the increased injector and displacement (base tune was for a 3.1L). Anyway, truck would come with the hardware to datalog and burn chips. I also set up the harness to be converted to MegaSquirt easily.
    Quick summary on the rest, in no particular order:
    Stock body and suspension
    Innovate MTX-L Wideband O2 Sensor/Gauge
    front and rear aftermarket sway bars
    Crane H260-2 cam, comp 1.6 ratio roller rockers, valve springs and timing set
    Big brake upgrade w/ SS lines, summit rotors and powerstop pads front and back
    warn manual hubs
    Centerforce DF clutch (the larger discontinued Rodeo size)
    OEM Limited Slip diff from a newer Trooper
    2" receiver hitch
    15" snowflakes with old 31x10.5 BFG A/T, matching spare
    I have a full extra set of four snowflakes with way old snow tires mounted
    Alpine stereo with nice speakers, amp and sub
    Lots of extra engine bits, including all the TBI stuff if that's your thing
    What's wrong with it?:
    Droops a little on the right side and pulls a little to the right, maybe it blew a shock or the t-bar is just fatigued
    Steering is a little loose and weeps power steering fluid from the box
    E-brake sticks, cables need lubricated - I just don't use it...
  • Canyonero
    • Sep 2006
    • 1112
    Also has a limited slip diff. OEM from a newer Trooper.
    • young gun
      • Jul 2010
      • 250
      Not in the situation to buy but I would love to see pictures and im sure that would help with the sale as well
      • Canyonero
        • Sep 2006
        • 1112
        Some details on the EFI swap.
        It's been 5+ years, but I have finally revisited the fuel injection on my Trooper. I have the same 3.4L long block, and now the entire intake setup from a 3.1L Camaro. I am using a Delco 1227727 ECU which is the hardened version of the 1227730, mounted under-hood and fully standalone from the...
        I don't have a whole lot of newer pictures because I haven't been driving it much in the last few years. Looks like a normal 1990 Trooper, not lifted or anything at a glance that would hint at extensive modifications - other than a 3" exhaust.
        • Canyonero
          • Sep 2006
          • 1112
          • Canyonero
            • Sep 2006
            • 1112
            Rewired back to MegaSquirt recently, may take it to a dyno shop to get tuned properly. I'd still like to sell it to someone who would appreciate it. Sadly, I just don't have time for it.
