NOS GM Performance 12.5:1 pistons PN 14044835
  • stalkerV6
    • Jan 2013
    • 20
    Six NOS GM Performance 12.5:1 pistons PN 14044835 - Never used
    $200
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 501
    What bore size would these fit?
    • stalkerV6
      • Jan 2013
      • 20
      In the picture, it states +1.00mm on each box and they are domed.
      • LeftVentricle
        Right aorta
        • Oct 2005
        • 501
        Right, but what engine is that a 1 mm overbore for? 3.1, 3.4?
          A forum community dedicated to J-body owners and enthusiasts. Come join the discussion about performance, engine swaps, modifications, classifieds, troubleshooting, maintenance, and more!
          that shows them being specified for the 2.8 w/1.0mm overbore.
          EDIT: it also specifies to be used with gen1 heads only?
          • Guest
            these are for the iron heads people.
            if you have e85 in your area, then I would find a 3100 block for the roller cam only, 2.8 crank, these high compression pistons, port out some iron heads, and pick up a iron head itb that stalkerv6 is about to put up for sale on here. 250 hp should be doable with that setup.
