(Borg warner turbo)(n20)(3.4/3400 engine)EXC.....
  • fasteddi
    • May 2013
    • 135
    I am selling alot of parts.
    3.4/3400 hybrid engine
    crower 03050 cam
    Ported intakes
    Stock 3400 heads(new seals, locks,Comp cam 981 Behive springs(expensive springs)
    RWD pistons=very high 12.56:1 compression
    I will give everything from the new oil pan to the intake with this engine...IE taylor lightining wires, dis stiff, crank sensor, TB, sensors(IAC KR IAT...exc)
    Engine runs fine, rebuilt 2k miles ago was running on e85. It was a turbo engine and had 80lbs injectors. I will give 22lbs injectors with the engine but the 80lbs are for sale as well. I will pull engine and deliver locally if needed. I live near toledo ohio(NW ohio)
    Asking 600 obo for the engine as is(no headers included)
    I have a one year old Borg warner turbo for sale. S366 T4 Turbo. Open flow .91 exhaust AR. I will also cut the 4.21 V band specific for the turbo DP and throw that in as well if needed. That thing cost somthing like 80 bucks as well.
    Im starting a new build so i am selling this turbo. Absolutly nothing is wrong with it. Ran 7.1xs in the 1/8 mile a few weeks back at 8psi but on a high compression E85 3.4/3400 engine.
    I will also toss in the turbo blanket with the turbo as well. Linked are the specs for the turbo. New they are arround 600-700 depending on seller and the blanket isnt some cheep crappy fleabay special. Cost 110$ new as well. Blanket is also 1 year old.
    Asking 575 Obo shipped to your door lower 48.
    Brand New Borgwarner S300SX3 S366 T4 88A R Turbo 177281 | eBay
    I have a 1 year old efi wet sniper kit for sale along with a bunch of add ons.
    Just for the sniper kit(upgraded to edelbrock n20 solinoids dual)along with the jets I want 325 shipped. It is one year old and looks like new. The n20 bottle is full so if its local pick up ill sell it for 300 and you get a full bottle of n20.
    I also have a zex purger kit-75 bucks shipped
    A dyno tune heater-75 bucks shipped
    Blow down kit-30 bucks shipped
    Summit digital window switch-50 shipped(never used)
    I also have a hobbs switch ill toss in for free with the kit.
    I have a Auto meter sport comp N20 in car guage-75 shipped
    I will sell the whole lot of n20 stuff for 575 shipped to your door. Its a full kit and would give you everything you need. Extra n20 lines fittings and bottle guages i will also toss in. Well over 900 invested and its only a year old. My loss your gain.
    I have a 1 month old set of Injectors for sale.
    EV1/hr High Z injectors. E85 Compliant. They work perfect and are damm near new. Changing engine set up so my loss your gain. I paid $338 for them a month ago. Asking 300 obo shipped to the lower 48.
    Will add pic in a few min when i remove them from car. Thanks
    Specs
    Typical Flow Rate in CC per minute: 840 CC/min @ 48 PSI
    Typical Flow Rate in LB per hour: 80 LBS/HR @ 48 PSI
    Typical Flow Rate in CC per minute: 800 CC/min @ 43.5 PSI
    Typical Flow Rate in LB per hour: 76 LBS/HR @ 43.5 PSI
    Resistance: 10 ohms (High Impedance, High Resistance)
    Voltage: 8-15 Volts, nominal 13.5 Volts
    Amperage: 1.0 Amps
    Pressure: Min 30 PSIG / Max 100 PSIG
    Spacers/O-rings Included: YES, on the injectors
    Injector Body Design: Metal and composite plastic
    Fuel Delivery: Upgraded single fuel delivery nozzle for superior fuel atomization
    Electrical connector type: EV1 (Minitimer, Jetronic)
    Overall Length: 2 7/8 inches, 74 mm
    O-ring to O-ring Length: 2 3/8 inches, 60 mm
    Diameter: 16 mm
    Orings: Top and bottom, 14.5 mm
    Warranty: 1 Year Warranty
    I also have these parts for sale as well
    Delta 260 cam and a delta 270 cam. 80 bucks shipped to your door for each.
    Multiple intakes, heads, fuel rails, harnesses, and injectors for sale.
    Also a BCC external crank sensor kit used for non dis hybrids that want to convert to DIS>125 shipped to your door along with a cranks sensor
    1/4 mile best 11.59@119mph
    1/8 mile best 7.47@94.9Mph
  • fasteddi
    • May 2013
    • 135
    I also have a speedway adapter to mount a th350 trans up to a 660. Comes with spacer and all the bolts. 60 bucks shipped to lower 48
    • fasteddi
      • May 2013
      • 135
      Open to offers or trades? What ya got? V6 stuff V8 stuff? let me know
