wtb (pic inside)
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    wtb (pic inside)
    I have tried a few different flanges to find out they leak because they dont cover the profile as great as they should so this is what I am looking for:
    Just that exhaust flange with some of the pipe attached to it (about 4" or greater). Let me know the $. I am located in Michigan. If the bolts/gasket can be salvaged, great! I'll take those too.
  • Guest
    ATP sells the flange you can use for that turbo.
    Advanced Tuning Products or ATP Turbo offers aftermarket turbo solutions and engine tuning accessories for high performance cars.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      I have tried going through them MANY times and they dont have it. Trust me, I tried. They even tried CUSTOM making me one and it leaks because it does NOT cover the profile all that well. I just want that exhaust housing flange like I originally wanted so I can be done with this.
      Thanks though.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        That is what I have tried the first time. It just doesn't cover the profile all the way. So off it went back.
        • Guest
          That is for a T25?
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            That is the "Steel - GT25/GT28R/GT28RS & T25/T28 Disch Flange" . I emailed them long ago and they said if anything that would be the one I'd want. I even sent them pictures of the turbo to confirm the order. ATP is a great place to shop, but they dont have what I need so it sucks that I cannot deal with them. So hear I am, wanting to buy...
              • 9190
              If you had a flange, could you figure out the piping yourself?
              If you can scan in the face of the turbo where the flange goes (preferably a PDF, or a high res image with a ruler next to the part), I can draw up a design in CAD and you can have someone make one (betterthanyou possibly, or a local shop). That way you will know it'll be an exact fit. I can even export it as a PDF so you can print it and test fit it on your turbo. Let me know if you are interested...
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                I could figure it out, but I am unsure about how high quality my scanner is...
                If I could just take my flange and have it remade with extra metal added to the surrounding edges that'd work fine too.
                Here are some images of what I mostly have gone through:
                The turbo:
                Very first flange from another source:
                Doesn't cover the profile 100% :
                Second flange (ATP) : I confirmed through an email if this is what I want...
                Didn't cover the surface 100% either (At first)
                So I shipped it back and emailed them again...
                They did much better:
                But it leaked when installed with out a gasket and even with a gasket.
                So here's my last pic of it:
                That is all I got for now.
                  • 9190
                  I MIGHT be able to do something with that last pic, but it would be tough... Reason I'd want a scanned image would be so the surface is flat. With it angled, its hard to judge if things are the right size, orientation, etc... I could try and send it off for you to look at I guess.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    Tomarrow I'll grab the flange and scan it rather than that digi pic. I'll try and squeeze a measuring stick in with it.
                    Thanks Brad.
                    • RacerX11
                      • 1060
                      Try taking a piece of paper, get some dirt on your finger, and trace the outline of the flange onto the paper, pressing the paper pretty hard. The dirt will leave a nice outline of the edge of the flange that you can easily scan.
                      '99 Z-28 - Weekend Driver
                      '84 X-11 - Time and Money Pit
                      Quote of the week:
                      Originally posted by Aaron
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        I do not know if this is something of use but I went and picked up the flange and scanned it.
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          Let me know if those images are of use.
                            • 9190
                            Had some spare time at lunch today... Tell me if this will work or where chnages need to be made. Once it is finalized, I can send either you or Geoff the DWG which can then be taken to a machine shop for fabrication.
                            Oh yeah, I went ahead and made a 3D version as well just for fun... I wasn't sure how thick it should be, so its probably not right. It shows it as 3/4" thick and the inset in the middle is 1/4" deep.
                            Just print the PDF, cut it out and lay it over the turbo to see how it looks, and take pictures as neccessary so I can tweek the drawing if needed.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              As soon as I get to the library or something (Printer is broke) I'll print it. That looks really accurate. Thank you.
