WTB good 2.8 crank with reluctorwheel
  • bjornmk1
    • Nov 2006
    • 266
    like the title says: I want to buy a good 2.8v6 crankshaft
    the type that has the reluctorwheel cast in.
    so this would probably have be a crank from a 1988-89 beretta/corsica.
    I will also consider a regrind crank ..but to a max. of .010" only.
    thanx,bjorn
    nothing's impossible-it's just a mindset
  • Guest
    I have one. Came from an 88 Fiero. Has light surface rust but not bad at all. I coated it heavily in oil and wd40 before setting it off to the side. Crank has been sitting in the stand up position as they should be when stored. Came from a 90k mile motor. It has a few small grooves in it so it will probably have to be turned. When I say small I mean small. It might only need a micropolish. I am not a machinist so I don't really know for sure.
    I wouldnt' mind $40 plus shipping. I think thats less then the core price I could get for it. If you can't find anything else on here then hit me up. thx
    Shaun
    • 1QUICKHATCH
      • 387
      I have one from an 89 cavalier, engine was running fine when pulled (no rod knock or any thing) not sure if it needs to be cut or not cause its still in the short block.
      if you want it $50 o.b.o + shipping (cdn.)
      14.96@91.47 in the 1/4
      9.63@74.36 in the 1/8th
      • bjornmk1
        • Nov 2006
        • 266
        whats the milage on the engine ??
        if the crank doesn't need turning/grind(standard size) than I'll pay you even more.
        gr.bjorn
        • 1QUICKHATCH
          • 387
          I belive it had 220,000 kms on it when I pulled it. I will pull it out of the block on tuesday night when I go to the shop and try to get some pics/specs for you.
            • 9179
            Shipping to Belguim is gonna be a bitch...
            • bjornmk1
              • Nov 2006
              • 266
              I know bzopi,
              but it's almost impossible to find one here that has a reluctorwheel.
              gr.bjorn
              • bjornmk1
                • Nov 2006
                • 266
                hey shaun,
                can you post some close up pics of the journals with those "scratches" ?
                thanx,bjorn
                • Guest
                  I will try but my camera doesn't have a macro setting so it will probably be blurry or won't be able to get in close enough. But I will try my best.
                  Shaun41178@hotmail.com is my email. Feel free to hit me up with just a quick hey and I will just email the pics to you.
                  • bjornmk1
                    • Nov 2006
                    • 266
                    just bought a regrinded crank
                    hey guys,
                    thanx for your reactions.
                    I just bought a regrinded crank from stan mizell engines
                    in florida for 65 $
                    so anyhow..thanks again
