Partially Parting out 92 and 94 LQ1
  • Mach10
    • Jan 2006
    • 232
    **EDIT**
    New layout, updated list.
    Here's my parts list. Everything that I COULD test has been tested, and examined. Because they are used, I guarantee nothing.
    Sensors/EFI: $13US shipped (Canada + US Main) for any of the following (unless otherwise noted)
    -Map (2)
    -TPS (1)
    -IAC (1)
    -CTS (1)
    -Coolant temp sensor (guage, 1-wire, brand new, installed once, replaced with unit from autometer guage)
    -EGR (2; 1 used but working, 1 brand new OEM replacement. Due to weight, $10 + shipping)
    -Purge control solenoid (1)
    -92 Fuel injectors (6) $20 shipped for the lot
    -92 Fuel rail (w/ regulator, working when pulled. Due to size $10 + shipping)
    Hard-Parts: (Prices don't include shipping
    -Front Manifold $15
    -Rear manifold $15
    -Power Steering assembly (2; one stock, other cored out) $10
    -94 upper Intake manifold (with sensors unless otherwise sold) $25
    -92 lower intake manifold $15
    Freebies:
    2 AC compressors; Unknown condition. Pay shipping
    *Bonus!* Any sensor purchase can have the connector w/ 6" pigtail FREE!
    PM or email me
  • thegreenmachine
    • Mar 2006
    • 3
    how many miles on the engines and how much are you looking for on the injectors and the egr
    • Mach10
      • Jan 2006
      • 232
      The injectors and rail are off a '92 with 180k (km)
      I'd rather get rid of the injectors AND the rail as a unit, since I can't honestly believe someone would want JUST the rail. Basically, what I'm saying is that while you will probably save a bit on the shipping, I'll charge the same as for the rail as for the rail AND injectors.
      The injectors are off a previously running car. All the sparkplugs have the same tan color, which makes me believe that they were all firing straight, not plugged, and no leaks. The motor isn't running now (or rather, I won't start it) because I fragged a cam follower (lifter).
      I'm looking for $20 for the rail and injectors together. Or I can bin the rail, and just send you the injectors to save you some shipping?
      The EGR looks spanky-new, but I dont have a reliable way of testing it. Say, $15 for the EGR?
      All prices are less shipping, of course. As a reference, the above parts sent to Iowa would cost about $10CDN (8.50US?)
      I've got a few parts boxes kicking around, so the first handful of people won't be getting charged for packing materials. I'll be charging the shipping rate only.
      Pictures of any of the components are available upon request.
      Note that I won't have the injectors off the 92 until at least monday, since I want to drive the car into the garage. Look in the DOHC tech section for sound-clips of what a truly fukt motor sounds like!
      • sspeedstreet
        • 282
        "1 rear manifold heat sheild"
        If the car didn't have the air injection pipes, I'm interested in this. $10.00US shipped to 93454?
        • Mach10
          • Jan 2006
          • 232
          It's an auto, so it doesn't have AIR.
          I would have to box the part so it doesn't get scrunched, so although it's lighter than hell, it gets charged by dimension.
          It's in good shape, though. Intact and not corroded.
          How about $13 shipped?
          • Mach10
            • Jan 2006
            • 232
            Problem fixed
            • Mach10
              • Jan 2006
              • 232
              Updated the for-sale list, as well as with prices.
