Good Wideband o2
  • gectek
    Banned
    • Aug 2006
    • 1472
    Good Wideband o2
    what are some companies that sell good wideband o2 kits for a good idea of what my car is acutally doing, so i can better tune my ga. i just got my dhp powrtuner and want to make sure that when i start tuning, i get it done good enough the first time that i dont have to start over from scratch
  • sharkey
    • Jun 2004
    • 2061
    i have an innovate xd-1 wideband kit. it comes with the gauge, controller and sensor. its a fully programable wideband setup, and you can change things to best suit your needs. it has a 0-1 volt output so you can run the wideband in place of your stock sensor and feed the comuter with it.
    aem also make s a half decent wideband.
    • gectek
      Banned
      • Aug 2006
      • 1472
      well i have another bung welded in for the wideband and i think i would tie it in to the dhp tuner with the analog to digital upgraded harness, so idk if that would make the other stuff obsolete or not, but i guess its worth a shot. does innovate sell them direct or do i have to go through somewhere else(third party)
      • gectek
        Banned
        • Aug 2006
        • 1472
        i may look more into the LM-1 rpm kit and see if i like that
        • scott0999
          • Aug 2006
          • 180
          I had a innovate lc-1. had a bit of trouble getting it to work
          then I got 2 datalogs out of it, and the next day it was dead. I got a replacement and had no luck with that one either. ended up selling it
          considering the high end stuff innovate makes idk if I just had back luck, or if the lc1 is junk
          my next WB will be this:
          '94 Cavalier Z24 3400 Turbo 5 spd
          • timg
            • Feb 2004
            • 718
            I'm running both the AEM gauge type and the AEM wideband controller (no display- running with an EMS).
            The Innovate LM-1 is great for multiple cars or for a tuner.
            Tim
            325 whp 350 lb-ft
            • Chris88CL
              Moderator
              • 212
              I used to have that zeitronix unit. It was good, but I didnt like the LCD display. Its ugly and was hard to view during the day.
