tuning part throttle question
  • scott0999
    • Aug 2006
    • 180
    when tuning part throttle, I normally increase the TPS% to engage PE mode. whats the highest I should bring that up to? if its too low and goes into PE mode, then the BLM stays at 128 correct? because I cant tune if the BLM isnt changing. so I would assume I should just keep the throttle low and let the RPM glide up when datalogging for part throttle tuning. but my concern is when the TPS is low, the MAP reading generally doesnt go very high. so it would seem im only tuning the lower MAP vs RPM ranges then
    '94 Cavalier Z24 3400 Turbo 5 spd
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    one way to do it would be to record your tps% vs rpm values to enable pe
    then change them across the board to say 80%
    then you can get some logs with varying map loads and rpm vs the near 80 %tps
    you can burn your new chip and raise the tps% across the board to %90 tps
    get some more logs
    raise it 95 do it over again, wouldnt really go much over 95 unless your comfortable with it and your not getting any kr or w/e
    you can then put back the pe rpm vs tps entries... road test and see where the motor is happy and where it wants the pe to be enabled rpm vs tps and you can adjsut them if you want
    some people like to leave the pe and tune with it
    lots of people have there different theories
    im sure ben will chime in and give us some good tips :P
    i wouldnt glide into it, becuase youll never get high kpa, jsut drive normal
    keep your eye on kr
