obd scan of my 2001 alero gls
  • scoopy03
    • Jun 2007
    • 53
    this post is regard to my first post http://www.automotiveforums.com/vbul...d.php?t=692294
    Car was driven half hour before the scan was done.
    Car was monitored for 5 min. Here are the results
    Abslt tps % 0.4
    Rpm 663-717 rpm keep changing like from 660s to 700s like every second
    Calc Load 2.4%
    Maf 0.49 - 0.51
    MAP 10.3 - 10.6
    Coolant 217
    IAT 126
    IGN Adv 19 - 21
    IT FTRM1 -18
    ST FTRM1 0.8 - 3.9
    Please let me know if this results sound reasonable or anything is pointing out any possible problem that my car maybe be having. The fan comes on. The car was a little above the middle line so around like 235 when I scanned it.
    Planning on doing 3800 Supercharged swap soon in either my 4cyl or 6cyl.
  • sprucegagt
    Old School KI
    • May 2005
    • 703
    What problem are you having with the car? Also your link is dead.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
    • scoopy03
      • Jun 2007
      • 53
      the fluctrating rpm's high coolant temperature. fans almost always on 5 minutes after starting the car and running it like up to the store regardless of the temperature outside. when i first got the car about 3 years ago it never had the guage in the middle it was always like around 190 not 220ish or 230 when the fans come on. plus on the intake it feels like u can cook an egg.
      • sprucegagt
        Old School KI
        • May 2005
        • 703
        Sounds like a cooling problem. What maintence have you done to the cooling system.
        • scoopy03
          • Jun 2007
          • 53
          only flushed out the radiator not a full flush
            Perhaps too the LIM gasket is leaking? Does the bottom of the oil fill cap look like mayonase? Is there any seepage outside of the intakes?
            I'd get a full flush before the dexcool starts to clog up your heatercore, thermostat/etc.
            • AJ2012
              • Jul 2011
              • 1
              Actually, one of the great things about dexcool is that one of things it contributes is to not clog, and would not clog either/or. Try looking for a minor leak in the thermostat housing which is actually separate from the thermastat. I know, sounds crazy, but its the same design as the Grand Am set up.
              • nixtux
                • Nov 2007
                • 282
                I have a similar issue on my 99. The temp gets upward to 210-ish in town when it's around 75F.
                Turns out the water pump isn't moving freely. Changing that this weekend and hopefully it'll be back to normal.
                Also with it running (wear gloves because it can be hot) feel the hose on the driver side coming from the radiator.
                After the thermostat opens up, if it feels kind of soft (there is air in the coolant system.) It's something like that
                anyway. grab a socket and bleed the air out from the valve on top of water pump.
