Where to find GM timing curves
  • TurboGt
    • Oct 2005
    • 154
    I am working on adding timing into my tune and wanted to take a look at some of the stock/modified timing curves gm has setup. I am running a mega squirt stand alone so I am looking for an excel file comparing rpm and map if possible. My car is forced fed so if anyone has a timing curve from their own car they would be willing to share that would be great.
    Looking on google I was searching for the Typhoon $58 and the TGP $8F code to see what/if I could see anything from this but came up with nothing. I have never looked over any of GM's code so any help would be appreciated.
    Thanks guys
    Mega Squirted Fiero
    How I did it here
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    heres mine, im running NA though
    DF code on a 16149396
    2.8L with goodies
    3100 top end
    port and polish exhaust, deshroud/polish CC
    and i must say im on lowest octane pump gas, also i have room everywhere to go up in timing, but i have been busy past couple weeks so i havnt done any tuning for awhile
    • TurboGt
      • Oct 2005
      • 154
      Thanks a ton Sli for the file!!!!
      Last night while searching I found Tunerpro and installed it on my computer, very nice program!! I found several files for the TGP and also the Typhoon, so I have a much better idea of what I should be aiming for ( I was playing it on the safe side). I just finished transferring the TGP timing curve into a megasquirt file and will be trying that out today to see if my car can handle it.
      If anyone else would share their tune that would be awesome!!!!!! Especially a Turbo'd 3400 one (hint, hint)
      Mega Squirted Fiero
      How I did it here
      • TurboProject
        • 47
        I'm not sure of all your specs but I posted my megasquirt tune on my site.
        It's for my turbocharged 3.4L iron head camaro.
        Wayne
        '94 3.4L V6 Camaro 5-spd
        Custom TO4E-T3 Turbo/Intercooler Setup
        Megasquirt Stand-alone EFI (www.megasquirt.info) controlling fuel and ignition timing
        My Megasquirt 3.4L F-body Install Guide:
        http://www.turbocamaroproject.com/me...tallGuide.html
        • TurboGt
          • Oct 2005
          • 154
          Very nice web page!!!!
          Your spark table looks a lot like the one I am running now, but you are running more timing in the cruse areas.
          Thanks for your help.
          Mega Squirted Fiero
          How I did it here
          • TurboProject
            • 47
            Yea, I bumbed up the timing in the low load cruise areas and it drastically improved my mileage. Tied together with lean cruising with a wideband I am getting 21mpg on my turbocharged camaro on my daily commute to work.
            Thanks for the compliment on the site. I made that diagram in hopes to get more 3.4 f-body guys on the megasquirt scene.
            Wayne
            • Joseph Upson
              You will need to use a spark table from an engine with the same casting material cylinder head for a reference point. The aluminum heads are fast burn so they don't require as much timing as you probably noticed when you compared the TGP spark table to the Typhoon/Syclone spark table.
