Attention Moates Emulator Owners
  • Joseph Upson
    • Oct 2026
    I'm still a little "tweaked" about the performance of my emulator or the lack there of however, there maybe a solution for others whom I know have had a little heartache from time to time with their units. It was not clear to me in the past and I only recall hearing mention of it once that Firmware and drivers for the emulator are two different things.
    There is no mention of firmware in my instructions for my APU-1 emulator which is not good because the update found under firmware solved a problem I was having with getting the emulator to verify the uploaded bin which usually signifies it's going to function properly when it does so successfully.
    Here is a link directly to the "nested" page I call it given the number of times I've visited the forum and never saw it and considering it's not under the file uploads and downloads section on the Moates site so you almost have to stumble across it. It would probably save Moates a lot of emails if it were more visible.
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    hmm doesnt apear to have clickable firmware links under the ostrich sections
