TunerPro File for dohc?
  • jmgtp
    • 1219
    Does anyone have it?
    I used to but my laptop died and it was lost. I believe it is a .xdf file.
    thanks,
    John
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
    if you're talking about the DF definition (91-93 3.4DOHC) then:
    PM me...
    if you mean the 2E definition (94-95 3.4DOHC) then:
    you need to point me to it, because as far as i know, nobody has been able to figure that one out
    EDIT: i was thinking about TP only, i guess tunercat figured it out........ they have a working 2E definition, but i have to wonder how easy it would be to make a TP definition from a TC DEF?
    • jmgtp
      • 1219
      I got it to work using just the .ads file that you can find by doing a search on the site. I want to say it was a post by Sil that had the file.
      I thought I needed the xdf as well but it seems to work just fine without.
      1994 Corvette
      LT1/ZF6
      3.7/42RLE
        well, yeah to datalog, all you need is the ads, i thought you needed a tuning definition, so i started mentioning XDFs
          http://60degreev6.com/forum/local_li...&catid=8&id=37
          91-93 3.4 DOHC and 93 3.1 4T60-E W body
          Found in this section:
          http://60degreev6.com/forum/local_links.php?catid=8
          I know that download is actually an .ecu file, but it contains the code mask and will work to tune. It's what I was using when I got all of my tuning stuff going, just haven't had the time to bug the snot out of Ben to teach me to tune.
