Ok heres the deal i just got a 1994 camaro with the 3.4 and heard there are some programs to wacth how the motor is runnig and have it graphed out, the thing is i need to no what ecu i have and i dont no how to do that iam a CARB kinda guy fuel injection and computers not my best thing if any one can help me that would be great
1994 Camaro 3.4 ECU?
Tags: None
the 94-95 F-body 3.4PCM isn't tuneable, but if you have a manual trans, you can swap to a 16149396 PCM. automatic is a different story: the stock tranny relies on the PCM to adjust line pressure, so you would either need to run an older tranny(such as the 93 F-body 3.4) or somehow retrofit a vacuum modulator onto the current one.
if you just want it monitored, but not being able to tune it, i can make an ADS for you so that tunerpro RT will work....
in that case: PM me your e-mail address, i'll probably have the ADS done by the time you read this.
EDIT: maybe not, is it an auto or manual?
DOUBLE EDIT!!!: i went ahead and did both auto and manual. so anyone with a 94-95 F-body that wants to keep an eye on their car(s), send me a PM with your e-mail address.Last edited by robertisaar; 08-08-2009, 11:38 AM.
