Tech 2
    Tech 2
    who has one or knows if it can transfer the BINs it pulls from FLASH PCMs to a computer?
    i was playing with a few programs that flash PCMs like the 94-95 LT1s and i was watching the exact commands it sent to set the PCM into the mode to allow it to flash the EEPROMs.
    point being: if someone can get the stock BIN off of a 94-95 3100SD PCM this way, the OBD1 or OBD2 conversions could be completely unnecessary.
    if the Tech2 can't transfer anything, what kind of wiring setup would be necessary for a laptop to be able to see all of the commands and data that a tech2 sends to the PCM while reading and flashing?
    Even if we had a bin, cracking it to see where the addresses for tables and such would be a nightmare unless we had that info... the later is what is lacking IIRC. I looked into this too with the same stuff the LT1 guys use...
      it would take time, and lots of it, but reverse-engineering ALL of it is possible. it uses the same processor as the LT1, which is a pair of 68HC11. there are also two flash PROMs soldered onto the PCBs, i imagine it's the same in the LT1.
      BTW: i am getting better at hacking through it. i'm not saying i could do the whole thing myself, but there are a few people i can think of that could do quite a bit to get the ball rolling if i couldn't... it's too bad the datastream doesn't push out a PROM ID, that would help tremendously.
        now HERE'S an interesting idea:
        that's what gets done to the 94-95 LT1 PCMs if the flash fails.
        does anyone happen to have an EEPROM burner that can read those types of PROMs?
        here is the socket that gets referenced:
        http://search.digikey.com/scripts/Dk...rds=ED80009-ND
        32-pin PLCC.
          • 9191
          I actually made an adapter several years ago to go from that PROM to a standard PROM to attempt to read the info with the reader I had.
            schematics?
            or
            did anything actually come of it.
              • 9191
              All I did was run a bunch of wires from an adapter similar to what you showed (second link) to a standard chip adapter. And no, nothing came out of it.
                i wonder if my BURN2 can read it as a chip it supports instead of finding someone with an EEPROM burner that can play with them...
                • chri0029
                  • Feb 2010
                  • 75
                  If someone has a tech2 in the MI area, I'd like to meet up and explore more in-depth Robertissar's initial question. BTW, the answer to the first question is yes, but not alone.
                  • Weatheralls Auto
                    Spinning out of control
                    • Dec 2009
                    • 536
                    I have a Tech2, but not near you lol.
                    The Tech2 does NOT pull bin from Pcm, just writes to.
                    I have been watching the way the Tech2 writes, however, my devices all have a buffer overflow and can not get the whole process.
                    Hoping with in weeks my new hardware will be ready!!!!!
                    As of April 2
                    Engine: 2006 SV6 3500 LX9
                    Trans: 2002 Getrag F23 5speed
                    Injectors: #36 GTPs
                    TB: 65mm TCE
                    Maf: 1999 3400 Montana.
                    Beverages: Ice Cold CANADIAN.
                      now that i didn't expect....
                      write commands could still be useful though, and knowing the way that the datastreams work with OBD1, the read command would only be slightly different...
                      • Weatheralls Auto
                        • Dec 2009
                        • 536
                        Once I get my hardware and a few OBD2 Pcms under my belt, I will work on pulling the OBD1.5 bin and rewriting.
                        Mapping the Tables will be your job lol.
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                          yeah, and what a lovely time that will be...
                          • chri0029
                            • Feb 2010
                            • 75
                            Sorry, I was wrong earlier. I can't save the bin to a computer. But I am trying do the opposite with a tech 2 and another tool. You should be able to download a stock bin (or close) from the downloads section of this site.
                            • DefEddie
                              • Aug 2009
                              • 194
                              You want to get on Monodax.com and search posts for AJxtcman.
                              He uses the tech 2 to hack the programs into caddillacs for tuning.
                              I believe he simply swaps segments though,but he does that offboard and uses the tech 2 for uploading.
