7730 questions
    Live life 3.7mi at a time
    • 4555
    For helping me with data, I could probably be persuaded to host some stuff for 'ya Robert
      john, i'd take you up on that offer(or attempt to blackmail brad), but i MAY have my own of getting what i need... even though i'm not entirely attached to the domain name...
        • 4555
        Brad might work something out with you, 60inclusive is now on his server
          for now i'm just having a bit of fun with this...
          got LOTS to do still, but it's quite a learning experience...
            • 9185
            We still have plenty of room on the server, so I have no problem hosting something up. If you want an actual domain, all I would need is a domain name to set up the site. If you just want a subdomain of 60v6, that would be easy as well (that's what Isaac has).
            • Guest
              #21
              I missed what type of vehicle this was going into, that would have a factor in what donor harness to use.
              FWIW, I used an '88 Cavalier Harness in my 1985 Jimmy, just because I already had it. I might have used an F-body harness if I had more choice.
              Just because you want to retain the DIS, I would say start with $A1, especially if you're not comfrotable with tuning yet. It will start and run the stock 3.4, might not be ideal but it will run, provided everything is wired correctly.
              $8D, while being said to have better fueling algorhythems, would not be something for a beginner to tuning to use. It requires either some direct HEX editing, or knowing which parameters in the XDF to manipulate to get the ignition timing correct. There is a difference between dizzy and DIS that requires some significant changes to get the timing correct. You can always swap to $8D later, using the same ECM, if you wanted, at which point I would suggest S_AUJP, since it has been enhanced by a few peole with some larger VE tables, and WBO2 datalogging, among other features. I use S_AUJP on a friends truck and it works nicely.
              • dusterbd13
                • Oct 2008
                • 102
                #22
                i wound up getting the 7727 ecm and harness from a 93 lumina with a 3.1. im hoping that this will at least get it up and running. ive gotten a lot of the harness built and modified, and as of tonight started gettinng it integrated into my 87 s10. be prepared for a barrage of stupid questions on here, s10f, and third gen.
                michael
