Need ECU Pinout 95 3.1l GA!
  • natehale88
    • Apr 2009
    • 30
    Hi guys long time no post haha.. Anyhow I am installing a MPGuino in my GA. It is a lcd mpg gauge from the Ecomodders Forum. its really nice to have mpg instrumentation! It would be cool to have some more 60v6ers over there so we can show em how efficient these motors are! I now average around 30mpg backroad driving and am shooting for 35 mpg in my 95 GA Auto with 306k miles. So I need to splice into the VSS, an injector wire(0v ground side), 12v constant and a ground and I shoould be all up and running on it . Anybody have a ecu wire diagram so I can put her on tonight??
    • 9190
    http://60degreev6.com/forum/showthre...iring-Diagrams
    94 3100 SFI should work for you...
    • natehale88
      • Apr 2009
      • 30
      Thanks alot! My only concern is that I found all I need there but no idea how to find say B28 or something since my ECU just has 3 plugs so no idea what harness thing each is on or what a or b or the numbers indicate lol. Sorry I'm not that ECU savvy .
      • natehale88
        • Apr 2009
        • 30
        Please help.. what the hell wire is injector ground/signal at ecu?
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          The "A" connector is clear. "B" is black and "C" is blue. The numbers for each pin are on the connectors themselves where the wires enter it. You'll have to pry open the grey-plastic clamshell-like cover to see them. I have scans of the PCM connector pinout pages and further details of the wiring. Just PM your email to me if you want me to send them to you.
          Injector grounds are all on the Blue connector. The injectors are all constantly connected to +12v from the fusebox (F/P INJ Fuse, pink wire) and the pcm opens/closes the individual grounds to complete the circuit.
          The ground wires are as follows:
          -C12 for inj#3 (pink/black stripe)
          -C13 for inj#2 (light green/black stripe)
          -C14 for inj#1 (black)
          -C15 for inj#6 (yellow/black stripe)
          -C16 for inj#5 (black/white stripe)
          -and for whatever reason C32 is for inj#4 (light blue/black stripe)
          1995 Grand Am SE
          • natehale88
            • Apr 2009
            • 30
            Thanks alot man.. It sure was frustrating as hell trying to guess what wires went where and stuff. How do I count the pins? Left to right or top to bottom?
              If you look at the end where the plugs where it plugs into the computer they normally are numbered.
              • natehale88
                • Apr 2009
                • 30
                Thanks guys haha I am just dumb.. I got it all spliced in and hooked up and stuff!! I must say it is pretty awesome having Instant MPG Instrumentation. It will definitely help me improve my fuel economy even more. Just sucks I cant tune my ECU any to make it run leaner and etc.. damn OBD1.5 ....
                  Not dumb,if you haven't gone through this before how were you supposed to know?
