Hooking up WBo2 through TunerPro?
  • 19Cutlass94
    • Apr 2005
    • 770
    Ive got a FAST dual WB ( http://www.fuelairspark.com/Products...er/default.asp ), and it has a 0-5v output signal wire. Does anyone know how to hook this up through TunerPro on a laptop? Ive looked through the directions and it doesnt say anything about it, other than the fact it has the output signal which can be recorded externally. Is there a way to hook it up through TunerPro or will I have to get a seperate program to do this?
    Thanks
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
    if you can find the conversion for turning output volts into AFR, i can write up a patch for you, then you'll just need to use a spare terminal/wire on the OBD1 PCM connector and i can throw the A/D read into the datastream.
