Lumina TBI ī93 3.1l computer
  • alah
    • Mar 2012
    • 6
    Hi everybody; I donīt have a part or model number but the output transistors are blown. By the numbers on them I canīt find the original? or substitutes.
    It has four with the following:
    44 33 M 324, 50 98 M 324, 8790M 317, 8790 M R004.
    If you need any more info, please let me know
    Suggestions as to info, original or substitutes, where to buy?
    Thanks, from Venezuela.
    What is the service number on the ECM?
    • alah
      • Mar 2012
      • 6
      Hi Dave; Service Number 16196391 BJBF. Then comes some bar code and, maybe serial number? 86BJBFKD32220382.
      Itīs all on one sticker; thought the rest might help.Thanks Alberto.
        Not sure how shipping would be but here you go: http://www.ebay.com/itm/1994-1995-LU...item1c1fbe4018
        Getting the components for that ECM is going to be a royal pain, If it's just the injector drivers you could steal them out of another one like a 1227730 but you'd have to do a lot of research to get a good aftermarket replacement transistor for it.
        • alah
          • Mar 2012
          • 6
          Hi Dave I know about the royal pain! Now Iīm not a mechanic, just an electronic technician. If anybody knows what type of transistors these are, PNP or NPN, or whatever I wouldnīt mind trying some substitute.
          Went to the ad, but it says they īdonīt ship to Venezuela, canīt understand why?
          If I get this to work, Iīll let you know.
          Off topic, would any of you say itīs safe to buy on eBay even from China? Thanks a lot!
            the injector drivers are FETs, i know that much.
            and i'm not sure how much of this will apply to you application, but
            mentions a few replacement injector driver transistors.
            • alah
              • Mar 2012
              • 6
              Thanks Robert but his model is different. It uses Field Effect Transistors, thatīs why the pins are called Gate, Drain and Source, G, D and S in the pic. Mine uses bipolar transistors Base, Collector and Emitter.
              Thanks, anyway.
              • alah
                • Mar 2012
                • 6
                Hi guys, this ECM has four drivers. Do they only control the injectors or something else? Thanks.
