Yes it is, I'm actually revisiting my tune today, its a bit warm but it shouldn't mess anything up.
power enrichment or WOT problem
Well for anyone having the same issue as discribed, and comes across this thread, the problem was the plug wires, mainly a single boot on the coil pack. Found it by soaking everything down, and fearing a shock by having the car running and moving every wire around. Only got a small shock though
Sent from my iPhone using my iPhone at work cuz I have nothing to do
The break may not have been in the coil boot, but that was the path of least resistance to ground. Your body had less resistance then the spark gap atm of shock.Originally posted by bob442 View PostWell for anyone having the same issue as discribed, and comes across this thread, the problem was the plug wires, mainly a single boot on the coil pack. Found it by soaking everything down, and fearing a shock by having the car running and moving every wire around. Only got a small shock though
I had a bad plug wire once, everything was fine at idle and reving in park (no load). But the moment I floored it in gear the misfires were noticeable.
It is good to have some resistance in the plug wires.
Some cheaper spark plug wires, the boot that protects the spark plug when attached, they can slide down and prevent the terminal from snapping into place.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
I'm not happy until I can feel it click. If I can't positively without a doubt feel it click into place I undo it and try again. Also dielectric grease rocks. Helps the boot slide on, will allow you to remove wires a year later and helps keep oil and water out. I don't put a wire back on without it.Originally posted by TGP37 View PostSome cheaper spark plug wires, the boot that protects the spark plug when attached, they can slide down and prevent the terminal from snapping into place.
Sent from my HTC One X using Tapatalk 2-60v6's 2nd Jon M.
And there always seems to be one cable that engages the plug w/o the click. Thinking it didn't lock, only to find it did when I feel it click pulling it off the plug.Originally posted by pocket-rocket View PostI'm not happy until I can feel it click. If I can't positively without a doubt feel it click into place I undo it and try again. Also dielectric grease rocks. Helps the boot slide on, will allow you to remove wires a year later and helps keep oil and water out. I don't put a wire back on without it.
Sent from my HTC One X using Tapatalk 21996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Ditto, but at least then I know it it had clicked and try to be more sensitive to the click on round two.Originally posted by TGP37 View PostAnd there always seems to be one cable that engages the plug w/o the click. Thinking it didn't lock, only to find it did when I feel it click pulling it off the plug.
