ALDL Connection Problem (FreeScan)
  • eric
    • Aug 2004
    • 4
    First off, the car I am trying this on is a 1991 Buick Regal 3.1L (VIN T). I am using the 410B definition codes.
    I have an ALDL cable bought from WOT Electronics (http://www.wotelectronics.com). I connected it myself and ran the ALDLtest v2.00 program. All 3 tests passed at 1200 baud on COM2 (DTR, RTS, RTS+DTS). I then opened FreeScan which was recommended to me by WOT Electronics. I started the COM2 port and I got the following:
    Supervisor: CSupervisor- Com Port started
    So, the COM2 port was initialized fine. Bytes sent and received were at 0 and did not move. I clicked "Force Data", got 4 bytes sent and 4 bytes received (It sent a Shut Up header and received a 4 byte response from the ECU.)
    The problem is I am not getting any data from my car ECU. My guess is that FreeScan is not sending data through the COM port because bytes are not being logged unless I explicitly click "Force Data".
    Is there anything I should know about configuring my COM port? Keep in mind that when I tried to run the ALDL on a baud rate above 1200, the tests would fail. Maybe FreeScan forces a baud rate that does not work on my setup (max 1200 baud)?
    Thanks,
    Eric
    • 9184
    Not sure, but this may help...
    http://www.60degreev6.com/index.php?...04045ebdd89c4f
    • Chris88CL
      Moderator
      • 212
      It sounds like your setup is doing the exact same thing mine was when I had the older memcal in it. Try getting a newer memcal for the same engine/transmission/vehicle and see if you can get it to work then. Everytime I'd click the "Force Data" button I'd get the exact same 4 bytes sent and received. After I swapped in a newer memcal it worked great.
