3.1 stalls only when coming to a stop
  • 94regal,3.1multiport
    • Oct 2004
    • 21
    fuel is good , has spark, no codes, and it wont fire????
      • 9191
      It has fuel to the rails... there could be an issue with the injectors.
        • Oct 2004
        • 21
        good point, aside from checking to see if a couple of plugs are wet after turning over, how else can i check?
          • Oct 2004
          • 21
          so ,the saga continues, i go out to turn it over and pull a plug afterward to see if it's wet or not and the freakin car starts right up. still no codes, ran it for 15 minutes and shut it off disgusted. it still "surges" when you open up the throttle, let off a bit and it's fine? also only in park, not in gear?pulling my hair out- help!!!!
