wiring data needed
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    wiring data needed
    for the 94-95 dohc, i need to know which wire the ecm ground is, which wire is the tps signal wire(blue, gray, or black) and which wire is the MAF signal wire(yellow, black/white or red) i believe it is the yellow one(pinA).
    • 9183
    RE: wiring data needed
    Here you go:
    http://www.60degreev6.com/images/Wiring_Diagrams/
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      SAVED TO HDD.
      very nice. thanx and i was right about the MAF after all. last thing how do i tell which connectors are which on the pcm? i noticed it referenced a,b,c, and d. on the pcm, however i see nothing and on the plugs they are labeled b,c,l, and m.
      if bad comes to worse though i can set my meter to beep on the resistence setting and locate the wires that way. and anywho you rule
        • 9183
        A - grey
        B - red
        C - green
        D - brown
