using a 5 speed with a 4t60e ecm
  • Wolf
    • 181
    how do I bypass the part of the ecm that wants to shift the tranny?
    i'm planning on putting a 94-95 3.4 dohc & ecm in my camaro with a t-5 & 3.42 gears
    1995 camaro 3.4 5-speed
    • 9184
    RE: using a 5 speed with a 4t60e ecm
    I think the 94 DOHC ECMs still used a MEMCAL, so there might be a way to edit the tranny code. I think Ben is trying to work on these years right now, but not sure how long it will be until he has anything figured out.
    • TurboGTU
      • Dec 2003
      • 453
      why not use a 5pd code from the DOHC on your ecm. I think the 730 can use the old 5spd memcal with some rewiring for non SFI.
      OK..I see that theres a low resolution cranks sensor going to the ICM and a cam sensor and crank sensor going stright to the ecm. So I guess the 730 is out of the question. The 93 regal 3.8 ecm looks similar..but some repining will have to be done.
      I'd still try and find a 5spd version for that year ecm.
      • Wolf
        • 181
        the problem with the 5 speed cpu is it has a 3.62 fdr, and I can't get that gear in a 10 bolt.(the auto uses a 3.43, and I can get a 3.42 gear.)
        would the cpu run the motor without tranny imputs(I know it'd throw a code or few if it did, but I can pull the ses bulb)
        I thought I seen a post (a long time ago) that some had crossed some wires or had a dummy senor for the auto tranny?
        • Wolf
          • 181
          ok, I found what i needed
          http://60degreev6.com/modules.php?op...rtid=49&page=1
          now to get one of these motors from thejunkyard and get started on this project
