Tuning OBD1.5 for boost
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    First time poster, Long time reader.
    I decided a few days ago to seriously look into getting RSM's supercharger kit for a 3x00 V6 in my 95 grand am. Since this car has OBD1.5 I know my tuning options are extremely limited especially since I need it to work the 4t60e too. The only idea I've had so far is to use a piggyback A/F controller but I realise that the stock ECU can only be tricked so much. I could also use the FFP underdrive pulley to slightly lower the output of the SC if necessary (~6psi. of boost is still better than vacuum).
    Basically I'm here in hopes some of you might have other, possibly better ideas.
    One other 95 owner has had a GM supercharger successfully installed on a 2.3L Q4 with a manual tranny. I'm not sure how much of a difference his ECU is from mine but he seems to be doing fine (albeit a little rich) with just an Apexi S-AFC 2 for fuel control.
    1995 Grand Am SE
    • 9184
    RE: Tuning OBD1.5 for boost
    Check out www.perfectpower.com I think they have probably some of the better piggyback systems out there.
    • Azrael
      • Apr 2005
      • 763
      Thanks! Options are always good to have. I've got a good baseline on what to do now: Headers -> 3400swap -> SC. I've found plenty of good basic tuning info over the net but I'll definitely have it dyno-tuned once everything is in.
      1995 Grand Am SE
      • timg
        • Feb 2004
        • 718
        http://www.splitsec.com also has some good piggyback systems. Vortech uses Split Second for quite a few of their supercharger kits. I'm running one on my Z34. Their FTC should be able to do ignition timing modification and MAP (or MAF) sensor modification. I believe some of their boxes are also available with additional external inputs.
        GReddy e-Manage may also work, though I don't know if it has a compatable crank trigger setup for ignition modification.
        Tim
        325 whp 350 lb-ft
        • Azrael
          • Apr 2005
          • 763
          With aftermarket fuel control I need to know which wires on the ECU to tap into. Does anyone know where to find the wiring/pin schematic for my ECU? The one for 3100's listed under the "In Depth > Computer" section doesn't seem to apply since it shows an input for a MAF sensor which my car doesn't have.
          Also is ignition retarding even necessary for low boost?
          Sorry for the simple questions but that's why I'm taking a year to do this.
          1995 Grand Am SE
          • timg
            • Feb 2004
            • 718
            For 7 psi, you should be relatively safe without retarding ignition timing. If you break 7 psi, you will definitely want it. I'm really glad to see someone taking their time and planning!
            Tim
            325 whp 350 lb-ft
            • Rook
              • Jul 2005
              • 25
              *bump*
              i also am planning on a 3400 swap + turbo setup on my 95 grandam obd1.5
              so would i basically need an air/fuel controller and ignition controller if im gonna run 9-12psi?
              anyone tried a standalone? im no tuning expert by any means, but would Greddy eManage or AEM EMS work? i know some shops in my area that could tune either of those for me with a dyno.
              but would say apexi s-afc work ok? or should i go with some other a/f controller?
              - Rich - Hey Ya\'ll watch This
              Cardomain Garage - 5 vehicles...i have a problem
              Curren Daily: 1999 Silverado Z71, RCSB 5spd V8
              Project Vehicle:95 GrandAm, Dead 3100v6...plan 3400swap
              • Azrael
                • Apr 2005
                • 763
                I had done a crazy amount of research after I made this thread. In the end I decided to go with an OBDII swap since just about everyone is capable of working with it. Also decided against RSM's supercharger and go with DPP's turbo kit for the considerably better power to price ratio.
                One option I seriously considered was Perfect Power's SMT6/7 piggyback system.
                1995 Grand Am SE
                • timg
                  • Feb 2004
                  • 718
                  Haltech also has a good piggyback system.
                  As far as tuning, PCM tuning and piggyback tuning are probably equally difficult. IMO, a good standalone is easier to tune than either a piggyback or stock PCM.
                  Tim
                  325 whp 350 lb-ft
                  • Manitcor
                    • 573
                    A couple people including myself have managed to change out the harness and PCM with a 96 ODBII harness and PCM, once you figure out all the wiring (normally only a couple connectors a couple sensors and change a couple pins on the body connector) you can do the actuall swap in about a day.
                    You options are much wider after that.
                    1995 Monte Carlo LS
                    3400 SFI 60v6
                    • gboogie99
                      they still can't catch me
                      • Nov 2005
                      • 348
                      where can i find the info on how to swap up to OBDII? I've got a 95 Ciera that I'm about to turbo and dont want to have a whole bunch of custom chips
                      • WhiteRaider
                        • May 2005
                        • 133
                        The 95 Ciera ECM is programmable with Tunercat. I have the definition file for it, but don't know how easily you could tune for boost...
                        • Manitcor
                          • 573
                          There is no posted article yet, I really need to sit down and do one, Im hoping to have some downtime over thanks giving to do this.
                          Ive also learned a couple things since I did mine that would have me do things a bit different if done again. First thing is if your car has a 96 or 97 model year this will be much easier. If not it can still be done but you have th extra issues of dealing with not only cross year but cross model idosyncarises.
                          Parts:
                          a complete harness (including injector harness)and PCM for your model/trim car from 96 or 97
                          96+ temp sensor
                          96+ Knock sensor
                          96+ shift position sensor (for t60 folks)
                          96+ egr valve
                          96+ PCM box with air intake snout
                          Since your doing a turbo I would reccomend larger injectors, you can either modify your injector harness and step up to GA injectors or you can get large Multec style injectors (I think they are avaible up to 45#)
                          Theres some splicing required and some pins that need to be moved on the body connector (very easy) if you are prepared ahead of time and have all your parts the actual upgrade can be done in a weekend.
                          I personally went to a 96PCM HOWEVER i have found that the 97 PCM has even more tuning options than the 96 and the 97 harness is still very close to the 95 harness for most cars (98/99 is a no-no they changes alot in those years). But there are differences in the 97 and I havent had time to look it up myself but I will as i plan to modify my 96 harness to accept a 97 PCM when I get the time.
                          I can give you assistance technically, it may help if you have a digital camera.
                          1995 Monte Carlo LS
                          3400 SFI 60v6
                          • gboogie99
                            • Nov 2005
                            • 348
                            i wouldnt know where to begin with a definition file. How hard is the swap to a 96 OBDII and how long does it take? Could it be done in a day?
                            • gboogie99
                              • Nov 2005
                              • 348
                              anyone?
