Why bother with an FMU?
Why not just get any 7727 or 7730 and drop in the chip from a 1989 Turbocharged GTP. Use the same sized injectors & Turbo as the GTP and you are pretty damn close to dialed in. No FMU or AFPR or timing box, just a factory ECU designed to run boost right out of the box. Later if you want to go up on boost or turbo size, you can modify the calibration tables using this guy's software:
http://www.gmpcm.com/phpBB2/index.php
Read all of the threads on that site, particularlty in the OBD1 section, and that should give you a pretty good idea of what to do.
Regards,
Brian C.
Regards,
Brian C.
