ECU Pin Outs W body DOHC
  • RebelGT
    • 642
    does anyone have the pin outs for the first gen DOHC W bodies, it should be the same as the MFI I believe?
    26+6=1
  • your_I.D.
    • Mar 2005
    • 337
    If nobody post them. You can always go to the public library. The have professional shop manuals for referance only. You can make photo copies of the wiring diagrams.
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
    • RebelGT
      • 642
      I know ben or someone has them, i used to have them, but i lost them somewhere.
      26+6=1
        • 9191
        92 work?
        http://60degreev6.com/discussion/kb....e=article&k=31
        • RebelGT
          • 642
          yep, that works, can you also tell me what type of crank and cam sensor this engine runs?
          26+6=1
          • RebelGT
            • 642
            also, where the cam sensor is located would be helpful to
            26+6=1
            • xtremesunfire
              • Nov 2005
              • 61
              do you got any for the 3400 ecu pin outs? or the 3100 is the same thing as the 3400
