I've got a problem with mt 3.1 91 engine...idles too fast...checked for air leaks, was told the IAC motor was bad..replaced that, and it helped...idles too fast till it warms up, then I can shut it down, and the idle comes down to where it should be...but not till I shut it down , and restart...any ideas ?
Fast idle
Find out what proper Idle Relearn Procedure is...Originally posted by Gitchesum View Post3.1 91 engine...idles too fast...any ideas ?
The Idle Learn Procedure:
This site's Idle Relearn Procedure:
Here's GM's method: from 1987-1988 manual on Speed Density Engine
