OBD I conversion?
  • 94gagt
    • Feb 2008
    • 29
    OBD I conversion?
    i read something on here about a OBD I conversion and got a little confused...
    am i just swaping pins or what? if anyone could dumb it down a but for me it would be greatly appreciated
  • 94gagt
    • Feb 2008
    • 29
    i have the obd 1.5 bs if that helps anyone
    • IsaacHayes
      Mr. Orange.
      • Apr 2006
      • 6030
      You have a 4t60-e right? So that means going OBD1 won't work since you need an ECM to control your trans. Going OBDII would be the way to go. swap engine harness/interior harnesses and ECM.
      • 94gagt
        • Feb 2008
        • 29
        the 9369 apparently has some extra ram for trans control... at least thats what i hear... i just dont know how the process is done.. id love obd II its just alot of work..
          • 9185
          Yes, the 9369 ECM is an option. The 93 GP was available with a 4T60E, so OBD1 is an option. But OBDII is a better choice.
          • red953.4
            • Feb 2008
            • 17
            I have a 95 3.4 camaro, is that OBD1?
            • geldartb
              The Situation
              • May 2004
              • 1994
              no that obd 1.5 too
              99 Grand Am GT
              1357 cam 227 233 .050 dur
              515 515 lift 112 lsa
              • IsaacHayes
                Mr. Orange.
                • Apr 2006
                • 6030
                technically it's OBD1, but it doesn't use the EPROM, it uses flash memory like OBD2 does. It's like a hybrid of sorts, hence the "OBD1.5" nickname.
                • 94gagt
                  • Feb 2008
                  • 29
                  i know oh a guy that claims he can change minor details on a 1.5... any one believe this to be valid?
                  • IsaacHayes
                    Mr. Orange.
                    • Apr 2006
                    • 6030
                    One of the companies that sells chips and stuff can do the same. Just remove speed limiter and a few other minor things with a hex editor, then upload the new program with a tech2. But nothing that really will let us open it up and tune it for mods and such.
