tunerpro rt not displaying data
  • americasfuture2k
    • May 2008
    • 146
    ok, so i am trying to datalog my info to send the info to have a new chip made. and i cant get anything to show data. i am running Tunerpro RT with the usb aldl cable from aldlcable.com
    i am running the 1227730 ecm on a modified fiero harness to run the ecm and the the 3500 lx9.
    i have tried this on both my vista laptop and my xp carputer. both showed the same results. a lot of nothing. the error count in TP RT rises rapidly. it does not display any data.
    what is going on? is it the usb aldl cable or do i have some settings that need to be set that are not?
    ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
    87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    You have everything set to the correct port? For usb you need to change the com settings. Also, is the timing right? I know I had to adjust it until it starts reading.
    I am using TTS data master. Similar, just not layed out the same.
    • americasfuture2k
      • May 2008
      • 146
      yes, i set the port to com4 in device manager and made sure tunerpro matched the comport. it connects just fine. how would i know if the timing is off? i forgot to mention it also has the DIS conversion.
