datalogging a 93 camaro
  • badass93
    • Jun 2008
    • 2
    I cant seem to find a program to datalog my 93 camaro with a 3.4 There seems to be programs out there for the 94 and 95 but not the 93. Could i use the 94-95 .def to datalog my car? i have an auto but i guess if i used the def for a 94 or 95 with a stick then i would be ok correct? or am i way off? anyone point me in the right direction?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    You look into TTS datamaster? Search them up, they might be able to help you.
    • badass93
      • Jun 2008
      • 2
      tts datamaster
      I looked into the tts datamaster but they dont have anything that would work with my ecm (16172693) or even my year and engine. I was told the EFILive was the only one that works with mine but i cant find a def file for it that would work with mine. I was hoping to run across someone who has this same set up and has been down this road. Is there a program out there? do i have to do a conversion in order to use datalogging software? any help is appreciated.
      • cheezx
        • Mar 2007
        • 9
        All the 3.4L F-body datalog defs should be the same (or at least similar enough to work). I would give it a try.
